So you have a wide band O2 meter? What does it do when the motor cuts out?
The vac retard unit on 930's depending on the year of the motor does nothing while boosting. If it is a later motor it might be a boost retard unit. I would guess it is the fact that the plug wires keep falling off or a bad MSD box.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Woops
What is the vacume at idle? I would do a comp test on the motor. Sorry Chris. Ask Todd for more money ![]()
Dean, I"m feeding him lunches as fast as he can eat!!
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Dean, the engine was running fine before the valve adjustment. I think the compression is probably pretty good. I'm assuming there is a vacuum retard on the distributor therefore it should have some effect right?
Oh Dean, the motor doesn't cut out just lunges/jerks, still continues to pull with full burst,, only it's kinda ugly.. A/F is 12.5 under boost 13.5 at idle.
If one plug isn't firing on a 930 it makes a HUGH difference in the way the motor runs. So I would focus on the plugs and the wires.
Do you have another MSD box to try ? Could be cutting out under demand/boost .
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Nope, just the one that came with the engine.
Why would it cut out under boost ?? T
When cylinder pressures are higher there is more spark energy required to jump the plug gap. Possibly the MSD can no longer store and rebuild voltage fast enough to properly function. Closing the plug gaps to .016" or so as a test may show a difference. Im guessing you know the firing order is correct. You do know that cyl # 1 is the one closest to the distributor right ? Also if you using a shop manual for the wrong model year make sure to be aware that starting in 1978 the ignition rotor rotates the other direction.
Kurt Williams
Thanks Kurt, I"m putting new plugs in today.. We'll see if that makes a difference.
T
delete this post
see next post
1987 930 1956 Chevy 3100 2009 Subaru Forester 2003 KX250 X2(I like my toys!!) Last edited by mark '87 930; 09-21-2006 at 04:55 PM.. |
did you fix your problem? Mine does the same.. but when I disconnect the O2 sensor... she runs great.
When mine 'bucks" there is tons of black smoke going out the tail pipe... so I know it's not burning the fuel. Runs fine while not on boost though. I also know my plugs, wires, cap, rotor are all new (I know this because I changed them).
1987 930 1956 Chevy 3100 2009 Subaru Forester 2003 KX250 X2(I like my toys!!) |
No it's still doing the same thing. I've been traveling on the west coast so have not had alot of time to work on it. Hopefully this week I'll get some time with it again..
Thread Tools | |
Rate This Thread | |
