First engine drop help needed PLEASE
I've got the motor and tranny dropped following Wayne's book but I cannot seem to get the transmission seperated from the engine.
I've got it seperated about 3/4" but that's all she wrote. It is a 3.2 with the G50. Wayne's book doesn't say anything else about seperating the two. HELP
1987 911 Coupe-Current ride 2007 997TT-Sold 2006 997 C2S-Sold 1991 964 Turbo-Sold 1987 911 Targa-You never forget your first |
Ya got to slide the t/o bearing shaft. Its on the passinger side
That is ya have to remove it
zbph10,
Check here for engine/tranny separation: Eng/Tras seperation? And don't despair about those broken studs - just think of this as an adventure where you get to learn about your engine, but you don't have to take it completely apart. Best of luck!
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Got it, thanks for your help.
Buttjoint--- The shaft is on the driver side and was a pain to get out. Unless I missed it I did not see this explained anywhere in Wayne's book? I made a puller out of allthread and a water fitting to screw into the shaft and happer it out. We went ahead and changed our minds and pulled the engine and transmission together, much easier IMO Here's a couple pictures of the kill Now its time to get the pig cleaned up, head studs replaced, and everything detailed and/or painted. Thanks for the help
Sorry Ithought it was the pass side, been a while since I did mine. Ya may want to support the halfshafts with some wire or something so your cv boots don.t get messed up. The bently manuel would help you when ya go to put it back together. cheers
I'll get them tied up tomorrow. Thanks again for the help.
