What is CFM of a CIS
Does anyone know the CFM flow of the 77 2.7 CIS system. What are some possible carb setups for replacing the CIS ?
I was interested in there is a max flow CFM rating for the CIS system in the same way a carb is rated. Like 400, 600, 800 etc
Old 08-27-2006, 12:16 AM
Slumlord
Porsche_monkey's Avatar
Shouldn't that be calculated from the bore, stroke and RPM?
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-27-2006, 07:19 AM
Here's a carb sizing calculator:
http://www.4secondsflat.com/Carb_CFM_Calculator.html
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 08-27-2006, 07:45 AM
Rex, thanks for the link.
Old 08-27-2006, 12:55 PM
jluetjen's Avatar
Re: What is CFM of a CIS
In order of increasing costs...
- Zenith 40's
- Weber 40's
- PMO 40's
- Weber 46's - Pretty much for race motors only
- PMO 46's - " "
Sure you can put a Holly 4-bbl on a 911, and it will run, but it will never run as well as the other options because of...
- A common plenum will introduce distribution issues which will result in unequal mixture to each cylinder. In this regards a 4-bbl will be worse off then CIS.
- The large plenum and long runners downstream of the single throttle means that the throttle response will be no better then with a CIS system. (Individual runner carbs and MFI have significantly better throttle response then CIS).
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 08-27-2006, 06:13 PM
Know of any rebuildable sets with manifolds hats etc ?
Old 08-27-2006, 07:30 PM
jluetjen's Avatar
Have you checked Pelican's classifieds or Ebay for things like "Porsche 911 Zeniths"?
BTW - Welcome to Pelican's Porsche Forum!
John
'69 911E
Old 08-28-2006, 05:05 AM
