Airbox Questions . . . .
I just received an airbox base which I purchased from a fellow Pelican- I am carving out the base plate from the stock airbox base (which conect the airbox to the AMF) and using it as an adapter plate for a new air intake like so...
![]() What does this connect to below??? Is this an unused opening in the airbox base which is plugged? I am not near my car to get a look under the "hood" so your comments are much appreciated.
I am sure someone will correct me if I am wrong, but I believe it goes to the oil tank neck on the right side of the engine bay. That is where mine goes but my car is not at all stock and could have been routed there in error.
That's where all the excess oil goes when you overfill the oil tank....
- Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Hmm. . . . now this change doesn't seem like such a bright idea, but then again I don't plan on over-filling with oil...
Superclyde My Toy: 1988 911 Carrera Venetian Blue : SW Chip : Dansk 100 Cell "High-Flow" Cat : M&K 1 in 1 out : Fuchs 7x9x16 : Strut Tower Brace : Momo Modena My "Daily Driver": 2004 Nissan Pathfinder - the dog hauler My first car: 1979 MGB |
You better find a "place" for the hose...or you will have a vapor-mess in the engine compartment....
best is to go back into the intake tract as stock. Or....tube into the side of a container, with a small cone filter on top and a drain valve on the bottom...more "junk" to add ! - Wil
THE IRONMAN
Just go to auto part store and buy a small spongious air filter...I have put this on mine along with the performance air filter...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
