Guest
Posts: n/a
help deciphering my engine #
i recently bought a project car (77 carrera)that the PO had been converting into a 964 look.
the PO had droped a fully rebuilt 3.2 liter enginge in the car just prior to my buying it. I intend to use the car for another project and was going to sell the engine however my mechanic has suggested that i put the engine in my 79 SC Targa. I know that the engine will fit however depending on the year of the 3.2 i will need to do other modifications. if its an 84 its pretty much a straight swap of the engine ignition unit & motronic with some wiring changes. if it is 85 or 86 then i will need to change axels and flywheel. the engine number is 63E06846. can anyone tell me the year model ? thanks Pazz 79 SC Targa |
Guest
Posts: n/a
My model year for an 89 911 Carrera is K so working backward on the alphabet to E I get 1983. Does that sound right? I think that a 83 motor could be installed in a 84 car so I would think it is an 84 3.2.
[This message has been edited by 89911 (edited 04-29-2000).] |
Guest
Posts: n/a
Pazz, your 63E----- engine number indicates that it was originally installed in an '84
3.2 Carrera. Incidentally, the new G50 transmission & larger clutch wasn't introduced until the start of the 'H' series models in '87. Andy ('69 911E in UK) |
Guest
Posts: n/a
Thanks for the info, much appreciated. looks like i now have a hard decision to make.
regards Pazz 79 SC Targa |
