Banned
crossover pipe? cat-bypass?
I wanted to know the difference between the cat-bypass pipe and the cross over pipe, I know what the cat-bypass pipe is, but where and what does the cross over do? Also I have a 911 SC 3.0 any suggestions, mainly for street use. Thanks
Old 08-31-2006, 09:04 AM
cat by pass
I went with the cat by pass and felt a noticeable difference. Cheapest ponies I ever bought.
"zumwoll" German for "to well being"---what happens when you drive a Porsche!
Old 08-31-2006, 09:30 AM
KNS KNS is offline
The cross-over pipe, if I'm understanding you correctly, is the pipe that carries exhuast gas from the right side heat exchanger over to the cat or pre-muffler (or by pass pipe). If your car is stock, you have one.
Kurt
Old 08-31-2006, 11:03 AM
DB_NC_95C2's Avatar
agree with zumwoll, you want a cat bypass and a sport muffler, but even those two haven't satisfied me, I am adding SSIs to the mix so I'll need a 2-inlet muffler and will be selling my cat bypass and Dansk sport 1-in-1-out muffler
'95 Porsche 993 Carrera, DACH-X, DACH-R, PSS10,RS Speedlines,RS StrutBrace, GT3TEK 993RS Aero
'06 Mini Cooper (O.Z,MTH, Milltek, M7)
http://www.hakkinen.com/spain99-mh1st-easy.mp3
Old 08-31-2006, 11:39 AM
wright77's Avatar
Wink
I installed the by pass pipe, still have stock heat exchangers, and it made my 78 'SC run much better and cooler.
Best investement you can make.
Bob
1978 911 SC
Old 08-31-2006, 01:58 PM
dmwallace's Avatar
I installed a Fabspeed euro pre-muffler in place of the catalytic converter and have been very happy with the result. I have stock exhaust otherwise. There is now much less heat coming from the left rear fender opening and the exhaust note is better and at a lower pitch than before.
'89 3.2L coupe
1997 Carrera 993 coupe
- Slate Grey Metallic / Classic Grey
1989 Carrera 3.2L coupe - departed
- Stone Grey Metallic / Silk Grey
Old 08-31-2006, 03:58 PM
rnln's Avatar
How about sound? Anyone experience cat by pass on 87-89 can post some noise comment? How much lounder?
Fat butt 911, 1987
Old 08-31-2006, 05:37 PM
Cat bypass sound is lower in note but not really any louder to my ears. I trade my cat out after the smog test every year. Without it my 911 passes every test but one here in Houston and that is why it goes back on for the day. Louder is cutting a second outlet in the stock muffler. Way louder.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 08-31-2006, 07:06 PM
rnln's Avatar
My car has a borla exhaust with 4 outlet, actually 2 dual. It is loud enough for me, actually a little too loud for my taste. I wouldn't want it any louder, lower is fine. I wonder if I swap in a cat by-pass, or hollow up an old cat, would it be much louder or just lower.
Fat butt 911, 1987
Old 08-31-2006, 10:35 PM
The cat weighed 20+ lbs., that's more than the stock muffler weighs in my 88. The straight thru test pipe let the engine run cooler, improved throttle response and slightly deepened the exhaust tone. Last week put on a modified/gutted stock (one in one out) muffler. This helped the throttle response even more and sounds pretty mellow until 4500 rpm and then takes on a more open sound up to redline. I think its running leaner now and will install a custom chip to max and match fuel and timing maps and improve power. I also drilled my airbox and use a K&N filter. None of these changes cost too much and seem to help the engine breath and don't effect reliability. I'm glad emission rules are not as stringent here as someplace like Ca.
Old 09-01-2006, 12:27 AM
I'm with Bill
Rick V's Avatar
Get it done by Nov. and bring it with you to the Dragon run, and I'll buy it from you. I'm going to do what you are going to undo.
Old 09-01-2006, 12:38 AM
