Shakenbake
Guest
Posts: n/a
Fog Lights not working
Relay is good, fuse is good, bulbs are good, switch checks out ok...what could be the problem? I recently installed higher power headlights (55/100)and on several occassions the fogs would not come on. I haven't traced down the wires yet..thought I'd post here first to see if anyone could give suggestions as to what this problem might be...Thanks
Chris Baker
Shakenbake
Old 04-28-2000, 04:24 PM
Early_S_Man
Guest
Posts: n/a
Are these factory option fog lights, and what year car is it?
Warren Hall
1973 911S Targa
Old 04-28-2000, 05:33 PM
Shakenbake
Guest
Posts: n/a
Hey Warren, yes the fog lights are I believe factory option Hella Fog lights. The car is a 1974 coupe.
Shakenbake
Old 04-28-2000, 06:02 PM
Dperlas
Guest
Posts: n/a
I just added a PIAA high output headlight relay and H4 (130w/185w) bulbs in my 81 SC. In side the driver side head lamp assembly are the turn on leads for the fog lamp relay tied into your low beams. When I pulled the lamp out to run the new wiring harness i found that my connecters were very corroded. I had to replace the connectors. This might be the root of your problem.
Dave
1981 911SC
1984 Alfa Spider
[This message has been edited by Dperlas (edited 04-29-2000).]
Old 04-29-2000, 12:03 AM
Shakenbake
Guest
Posts: n/a
Found the problem...traced all the wiring and connectors and found a bad connection between the relay and headlight connection...it's back in business..thanks for the help
Shakenbake (Chris Baker)
1974 911 Coupe
Old 04-29-2000, 11:07 AM
ove
Guest
Posts: n/a
I have a problem with my rear fog light.It doesn`t work.Have replaced the bulb,the fuse is ok and the wiring looks ok.The light in the switch disappears when i turn the fog light on.Is this normal?
Any help will be appreciated!
Old 05-01-2000, 11:19 AM
Superman
Guest
Posts: n/a
This is the second timne on this BB I have heard of rear fog lights. What's a rear fog light? Is this the back-up (reverse) light?
'83 SC
Old 05-01-2000, 01:02 PM
ove
Guest
Posts: n/a
Hello Superman.
Here in Europe we have a rear fog light as an option.In fact here in Norway it is mandatory.It is a red light installed on the l/h side just below the rear bumper.
Best regards. Ove
83SC
[This message has been edited by ove (edited 05-02-2000).]
Old 05-01-2000, 01:39 PM
