SC Brake Upgrade ??
I am looking for some brake upgrade combinations for my SC that require minimal machining, on a medium budget. I am running 15" wheels. The obvious is 78-79 turbo brakes with full floating set up, but this is not cost effective at this time. I was wondering if anyone has done early 944 turbo calipers on Carrera rotors up front, is this a bolt up?? Also I have heard of 964 4 piston rears and a Carrera rotor on the front of SC's. Lastly would be the 917 style calipers with later non-floating discs?? Will this work ?? Any advise would be greatly appreciated.
One of the simplest upgrades is to install Carrera 84-89 calipers and rotors. The calipers bolt up and they are wider as to fit the wider rotors. The rear calipers have bigger pistons, so a Carrera proportioning valve may be a good idea.
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
OK, who's got that link. C'mon, you all know the one I'm talking about. Was it Bill V.'s??
xw, this is what you need to see. It details the options for you in order of cost and effectiveness. Try a search. Edward
993: retired Trackmeister, now daily driver heaven 911SC: resident Trackmeister-in-progress |
You mean this one?
Well I didn't post the question, but thanks, Bill! I can't tell you how often I've seen posts or references to your excellent write up. You are a real asset to the Porsche community.
Edward
Everyone should send Bill a beer ...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Formerly bb80sc
Installing Boxster calipers and Carrera rotors front and rear is a nice setup. However, some will argue the value of going with the Boxster over the Carrera calipers. I have the Boxster setup on my SC -> 73RS Replica and it's nice and balanced.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
I don't know if anyone else has noticed but a lot of the folks here are umm... frugle
My dad has the Boxster/Carrera set up and finds it well balanced and loads of breaking power.
Less brakes, more gas!
Took me a few hours at most and I had Carreras F&R. Works very well and I have no prop valve.
-michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Formerly bb80sc
I was under the impression that being able to see the "Porsche" script on the calipers would add 10 HP ![]() In all seriousness, I basically stole the front setup, so it did not hit the pocketbook nearly as bad for the rears. Would you see any benefit adding a proportioning valve with the Boxster setup? I have not had her on the track yet, but she feels balanced on the street. I fear the rears may prematurally lock on the track, though....
Mad scientist
Sorry for barging in like this, but there is one issue that does not seem to be discussed when upgrading brakes. That is brake pad size versus pedal response.
How does this sound? If you add the same amount of force on a big and a small brake pad, the small pad will compress more because the surface pressure (force/pad area) is higher. Since the small pad deforms more than the big pad, the brake pedal will feel more spungy with small pads. With that in mind e.g. the Boxter caliper upgrade will give a firmer pedal response which gives a better sense of control compared to using a Carrera calipper which has the same brake pads as the SC. Or am I totally off?
'84 911 Carrera '91 928 S4 You can't make a racehorse out of a bull, but you can make an awfully fast bull. |
Another factor to consider for track applications is pad cost / life of the pad. Carrera calipers are good, but hard track uses wears out a set of quality pads in a few track days. For this reason on the 3.6 SC, I went with a modified set of 'Outlaw' 4 piston calipers. The plan is to get about 12 to 20 track days on a set of pads.
Pedal feel in a Porsche is almost entirely a function of the master to slave ratio.
Is the 17mm master cylinder of the earlier cars good enough or is a 19mm required? I have done the Carrera front/rear upgrade but have not finished the project yet. Thanks to this post I now know I need the p/v! I am pretty sure my 72 has a 17mm master. I have searched, but found no specifics. Any advice greatly appreciated.
72 T 3.2 |
Formerly bb80sc
For Carrera f/r brakes that will work fine, A slightly better m/c would be a 20.5mm m/c 901.355.012.04(ATE# 3.2120-3901.3). They are not easy to come by
Mad scientist
Any suggestions?
