WydRyd's Avatar
Question Turbo guys: Air Filter placement?
I'm thinking of just fitting an air filter directly to the turbo's compressor and perhaps ordering a heat/weathershield protecting cover around the bottom of it, to reduce road dirt going into the filter.
Anyone on this board running a filter directly off the turbocharger?
How quickly does it actually get dirty in this location? If I were to go down this route, I'd invest in a good washable & oilable air filter.
I'd also think the air around that lower area would be much cooler than the air in/around the engine bay, right?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-25-2006, 06:29 PM
Crotchety Old Bastard
RarlyL8's Avatar
Old 09-25-2006, 07:51 PM
David's Avatar
If you're getting rid of CIS it's no problem. I don't have any pics of my set up on this computer, but you could search for my previous posts. Due to the higher flow, I made a new larger intake pipe to the compressor. This may be more trouble than it's worth. Others, like DonE, have run a line straight out of the compressor around the inner fender and back into the engine compartment. I don't see why you could go straight off the compressor with a filter as long as it's sheilded from road debris.
Old 09-25-2006, 07:59 PM
WydRyd's Avatar
Thanks guys. My local auto-parts store has a stainless steel arched heat/weather shield specifically designed for air filters. I think I'm going to give it a try and bolt a K&N directlky onto the GT35R I'm planning to install shortly. I had the compressor inlet machined down from 4" to 3.25" to make it easier to route intake pipes, but I think I'll go with the direct bolt on solution for now and see how that works out. I can always route the intake plumbing into the engine bay if I find it's getting dirty too quickly. At least I'll save some $$$ with intake plumbing for now
Merv
'89 911 Turbo Cab
Old 09-25-2006, 08:33 PM
I think it is way to dirty to put the filter there.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 09-26-2006, 05:42 AM
mine was underneath for a while, but I was always thinking "what if" I moved it here for now.... still looking for the best spot
Old 09-26-2006, 05:57 AM
It only takes a pebble the size of a pea to lunch a compressor blade. There are fewer pebbles as you increase the distance from the ground. Are exposed filters immune from road splash and mud too? No.
Sherwood
Old 09-26-2006, 10:54 AM
David's Avatar
Here's a pic of mine. I built the inlet pipe from a 3" OD aluminum 90°. Even with the tightest elbow I could buy, it had to be cut and welded in a couple places to fit. I would have preferred to use 3-1/4" tubing but I couldn't get anything bigger in there.
Old 09-26-2006, 11:55 AM
The owner of this one lunched two new compressors because of the location of the air intake (enclosed air box over K&N filter). Note position of air box directly behind tire.
Sherwood
Old 09-26-2006, 12:32 PM
WydRyd's Avatar
OK, I get the message. I'll do as Jerry and David did above. Can't afford to take the risk
Thanks all.
Merv
'89 911 Turbo Cab
Old 09-26-2006, 04:14 PM
