SMC SMC is offline
Route spark plug wires
Can someone show me a attractive way to route spark plug wires on a 3.2.
Thank you for your time.
1988 911 Carrera
1970 911T
1972 911E Roller
Old 09-07-2006, 12:17 PM
I don't know how "attractive" these are, but here you go:
Hope that helps
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 09-07-2006, 12:56 PM
Here's how I run mine on my 86 3.2 without the wire separators which are not necessary IMHO:
The 84-85 3.2s run them behind the fan housing too.
Cheers,
Joe
Old 09-07-2006, 01:05 PM
charleskieffner's Avatar
wire separators are a good idea. if you cant find any .........take a zip ty wrap loose around both wires, then take another zipty and go in btwn both wires and cinch tight. snip tail off and waaaa-laa..........separators! functional and will add at least 400 HP! LOL!
Old 09-07-2006, 01:10 PM
SMC SMC is offline
Is that a bungee cord on your distributor?
1988 911 Carrera
1970 911T
1972 911E Roller
Old 09-07-2006, 01:28 PM
Had separators and lost hp that's why I got rid of them.
And the bungee is to hold down my Jeep Cherokee HEI distributor cap.
Old 09-07-2006, 01:32 PM
ivangene's Avatar
OK this is a really old thread - I KNOW!!!
but I was looking for some info, saw the pic in post #3 and seriously am without words!!
(and those of you who know me....know that is something!!)
FWIW I used my stock looms and a tapered hand reamer (to start) and a 5/16 reamer in a cordless drill to route my wires with the factory parts - like it?
Ed M
86' Coupe
Old 03-20-2012, 07:58 PM
Don't know if you saw the other recently revived thread, but this is how I did mine...
Old 03-21-2012, 05:02 AM
Northern Motorhead
wildcat077's Avatar
Here's another option ...
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 03-21-2012, 06:01 AM
ivangene's Avatar
beautiful KC!!!
loving the heat backdate!
Phil, I thought bundling was not desirable?
Read a few posts on that -
Ed M
86' Coupe
Old 03-21-2012, 06:28 AM
Northern Motorhead
wildcat077's Avatar
Ed,
I haven't had any issues yet ... i guess as long as the wires are new and not chafed anywhere i should be good to go.
I read up on some of the conflicting posts regarding this issue,although i did like you with my original separators,i reamed the openings .325 as the Magnecores were thicker than the OEM wires ...
Cheers !
Phil
Cheers
Phil
Old 03-21-2012, 10:12 AM
Formerly known as Syzygy
Canada Kev's Avatar
I'm curious about that as well. What about the guys that have twelve wires? Often they're bundled together over the fan housing. Really, there doesn't appear to be enough room to have them all nicely separated like KC did (looks good, BTW).
Kevin
Old 03-21-2012, 04:17 PM
Grady Clay's Avatar
The reason to separate wires is one wire (firing the sparkplug) will induce voltage in a parallel wire.
The closer the wire and the longer the distance paralell, the more the induced voltage.
With our high-current, high power CD ignition systems, the more current the higher induced voltage.
This is magnetic induction due to the changing magnetic field from the changing current in the wire that is firing.
This is undesirable as the induced voltage can actually cause a spark in an unintended cylinder.
If that cylinder has the intake valve open and air/fuel mixture is filling the cylinder then it is possible for a flame to go back up the intake.
Not good for proper running.
For example, when #6 fires, #4 is in ‘intake’ cycle.
If the #4 and #6 wires are parallel and in close proximity (clamped and zip-tied together), it is possible to induce a spark in #4.
There may also me an electrostatic effect.
I am told this is low compared to the magnetic effect.
There is no advantage to 'bundeling' the wires.
So…
Separate your wires.
The Carrera separators work just fine.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-21-2012, 04:59 PM
