Crotchety Old Bastard
RarlyL8's Avatar
EVIL ENGINE goes Twin Turbo - Your Chance to Design the 930tt Exhaust System
As many of you know I have assembled and built a mule motor - the EVIL ENGINE - out of spare parts, many of them given to me by generous Pelicanheads. I can't thank you guys enough. The plan is to use this mule for fitment purposes so that the engine in my car can stay there as long as possible. With a mule we can try many configurations and fiddle with this and that with no worry of time constraints. No idea is too wild and pictures of what others have done are a big plus.
Right now I have 3 exhaust systems to work with:
- Early Heat Exchangers from a '73T
- 993 Bishoff Heat Exchangers
- Shorty Headers
We need to pick one of these systems as a starting point - unless you can convince me otherwise. Price is a factor. This may be the worlds only twin turbo conversion on a budget. I have a garage full of parts and a good welder, we can make it happen.
Here is the 993 Exchangers vs Shorty Headers. Pros/Cons?
Old 09-12-2006, 08:23 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
One question, are you looking to hook up the heating system too? Or are you only concerned about the twin turbo install.
If only the twin turbo install, I would say the shorty headers hands down. I feel its a huge space saver under the engine and you won't have needless items collecting dirt and muck. There will also be a smaller number of things preventing your hands and so forth from working under the engine.
Just my very humble thoughts,
Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 09-12-2006, 09:53 PM
WydRyd's Avatar
Agree. If you don't want/need heating, go with the shorty 993TT style headers. They'll spool the turbo up a bit quicker too
What type of oil drain system will you use? Gravity drained to the valve covers (u'll need to raise the turbo a bit with a short J-pipe), or using a scavenge pump?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-12-2006, 10:03 PM
the 993 HE would work nicly for multi use but the shorties would work best for quick spools. but that said you are doing twin turbo so who really is worried about quick spools?? either way 2 little J pips some falnges and your done. pretty straight forward. I would think the HE may be better due to them keeping heat in the tubing which drives a good portion of the turbo anyhow!
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 09-13-2006, 05:50 AM
RarlyL8's Avatar
Heat is a factor but I can fabricate some small enclosures for the shorty headers if need be.
What about flow and header design? The 993s have larger ID primaries that taper to a large collector. The shorties collect at the same ID as the turbo inlet (1.5") which is very small.
Old 09-13-2006, 06:08 AM
klaucke's Avatar
If heat is a factor, definately use the 993 heater boxes/headers. The shorties won't provide enough heat even if you do box them in. As Ben said, quick spooling shouldn't be a problem even w/ the 993 units.
Old 09-13-2006, 06:27 AM
Original Owner
tsuter's Avatar
Can you take a picture looking down into the flange of the shorties. That'll tell a lot about how well they'll work.....
And I guess you run a turbo integral wastegate with those????
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 09-13-2006, 09:31 AM
RarlyL8's Avatar
The turbos are K16s with internal wastegates.
The shorty headers are exhaust port matched and also match the turbo inlet (a very tiny 1.5").
Old 09-13-2006, 09:53 AM
Original Owner
tsuter's Avatar
You mean about this big???
I took this one off my 1.8T VW turbo. It was spooling too fast and out of gas by 5500RPM.
tsuter
Thaaaats Right!!
Old 09-13-2006, 10:00 AM
RarlyL8's Avatar
Yes. These are stock 993tt turbos. The exhaust inlet is surprisingly small.
Old 09-13-2006, 11:02 AM
user & abuser
I've been wanting to see someone high mount the turbos.
makes gravity feed much simpler, and if placed propely i believe it can be made to start with colder air... i guess this is pointless if your planning on intercooling.
i guess part of my idea, comes from my thinking of clean air above, dirty air below.
ps- i like the shorties....IMO turbos can never spool to fast.
vini vidi vici
Old 09-13-2006, 11:41 AM
resident samsquamch
sand_man's Avatar
Man, I love the simplicity of the "shorties"!
-jeff
Old 09-13-2006, 12:31 PM
RarlyL8's Avatar
Should not have to gravity feed anything, this is a 930 engine. The plan is to use everything 930 and adapt it to twin turbos. The oil drain lines from both turbos will route to one collector to be pumped back to the engine.
Old 09-13-2006, 02:21 PM
WydRyd's Avatar
What about a muffler? Are you planning to use a muffler, or just straight dump pipes? If you plan to run a muffler, it'd be easier to plumb one in with the side mounted configuration IMO.
Merv
'89 911 Turbo Cab
Old 09-13-2006, 04:56 PM
RarlyL8's Avatar
Good question about the muffler(s) - that is an issue to be discussed here as part of the exhaust "system". Side Mount vs Rear Mounted Turbos.
It would appear that running a couple of cherrybombs on side mount turbos gives an advantage to that configuration. Rear mounted turbos leave little room for a muffler.
Here is a picture of Mark Hargett's beautiful side mounted turbos:
And here is a picture of Amac's bad-ass rear mount turbos:
Vastly different designs. Here are the turbos I will be working with:
So what are the pros and cons of each configuration?
What engineering obstacles do you see for each configuration?
Old 09-13-2006, 07:09 PM
user & abuser
maybe just a noob observation.
your turbo are the same, whereas the ones in the above picturs are mirror images of each other.... this is gonna make your engine aysemtrical... dunno if that makes a problem
vini vidi vici
Old 09-13-2006, 07:22 PM
beamonk's Avatar
Send a message via AIM to beamonk
If you need any turbo rebuilding or parts, the best guy around is right here in Tuscaloosa. Let me know if you want to cantact him.
John Brasfiled
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 09-13-2006, 07:30 PM
WydRyd's Avatar
RarlyL8, I'd be going side mounted turbo's plumbed directly into a Magnaflow dual in/out muffler. Get the biggest Magnaflow you can find to fit the space available. They are a cheap muffler and are also of a very high build quality.
You don't it TOO loud, so I'd shy away from dumping straight out to atmo. Just my 2c worth
Merv
'89 911 Turbo Cab
Old 09-13-2006, 08:13 PM
resident samsquamch
sand_man's Avatar
Hey Rarely, another thing to consider: which turbo arrangement provides for the easiest access to other engine parts that will need servicing - i.e. valve adjustments, spark plugs, etc. Though I said I like the simplicity of the shorties (side location), it looks as though you'd have a helluva time adjusting the valves without removing a bunch of ***** (referring to Hargett's engine...maybe it's just the photo angle).
The rear mounted turbos look like you'd only loose access to the chain covers, and that's not something you typically mess with anyway (barring a leak or cam timing adjustment).
Just food for thought...
-jeff
Old 09-14-2006, 03:46 AM
RarlyL8's Avatar
My turbos are a matched set from a 993tt.
Engine access is paramount. I fiddle with my engine a lot and engineer everything for quick access. That is one reason I considered rear mount turbos - they are completely out of the way. Spark plug #1 is a real PITA to get to on a 930 and that IS complicated by rear mounted turbos due to the plumbing involved.
On the other hand you only need to adjust the valves every 15K - about 2 years for me.
What do you think about using the shorty headers AND rear mount turbos? Pipe lenght should be about a foot on each side.
Old 09-14-2006, 06:27 AM
