Is this the meter that shows capacitance and what setting do I use
Please help
Old 09-16-2006, 04:03 PM
OOPS
Old 09-16-2006, 04:05 PM
haha
Old 09-16-2006, 04:06 PM
my other son
Old 09-16-2006, 04:07 PM
Early_S_Man's Avatar
Porsche Crest
Kekumu,
Yes, that meter will measure capacitance on the five green scales, however, you will need to extend the test lead banana plugs [that normally plug into the three sockets at the bottom] by wrapping with solid 20 ga wire to be able to plug into the Cx socket adjacent to the F range labels. Or, you could modify a couple of general purpose clip leads with alligator clips on both ends -- by cutting off one alligator clip, and soldering a 1/2" piece of straight 20 ga bare wire to the wire, then cover all but 3/8" of the solid wire and soldered splice with shrinkwrap tubing. Be careful not to allow the test lead wires to short together outside the Cx socket.
Good luck!
edit:
After looking at the Permatune tech page, the meter would need to measure up to 275 uF, and the meter pictured above doesn't have a range high enough to make such a measurement! It is limited to measurements of 20 uF or less.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-16-2006, 06:22 PM
