rteague's Avatar
Long term effects of engine running lean
Replaced injectors with new bosch. new bosch fuel filter. new bosch fuel pump. cat bypass sport muffler cam timing set for max torque. still running lean. what are long term short term effects of lean fuel mixture. thanx r.t.
84 m491 blk/blk coupe
1st Place The Ventura Show
September 9 2006
Last Place The Ventura Show
September 10 2006
Old 09-23-2006, 05:44 PM
I'm with Bill
Rick V's Avatar
Lean is mean but only in a quatermile. When an engine runs lean it runs hot, short term is frying your oil prematurly. Long term is you could burn a valve, melt a hole in the top of a piston, etc.
Have you ever seen the inside of an engine that has run too much nitrous? same thing it just takes longer to happen.
Old 09-23-2006, 06:04 PM
rteague's Avatar
I understand heat is an issue. engine doen't run hot. Spark plugs are a light brown color. I read previous thread ponting at the AFM. Any suggestions?
September 9 2006
September 10 2006
Old 09-23-2006, 06:19 PM
Registered abUser
TerryH's Avatar
Light brown/tan is good. Are you having other issues? Pinging/knocking?
'81 911SC Coupe SOLD
Old 09-23-2006, 06:29 PM
ruf-porsche's Avatar
How do you know it running lean? Hookup an AF meter?
Old 09-23-2006, 06:33 PM
rteague's Avatar
Will hook up af meter and report findings. Going to chase long finned tuna right now. thanx r.t.
September 9 2006
September 10 2006
Old 09-23-2006, 06:47 PM
