Long term effects of engine running lean
Replaced injectors with new bosch. new bosch fuel filter. new bosch fuel pump. cat bypass sport muffler cam timing set for max torque. still running lean. what are long term short term effects of lean fuel mixture. thanx r.t.
84 m491 blk/blk coupe 1st Place The Ventura Show September 9 2006 Last Place The Ventura Show September 10 2006 |
I'm with Bill
Lean is mean but only in a quatermile. When an engine runs lean it runs hot, short term is frying your oil prematurly. Long term is you could burn a valve, melt a hole in the top of a piston, etc.
Have you ever seen the inside of an engine that has run too much nitrous? same thing it just takes longer to happen.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
I understand heat is an issue. engine doen't run hot. Spark plugs are a light brown color. I read previous thread ponting at the AFM. Any suggestions?
Registered abUser
Light brown/tan is good. Are you having other issues? Pinging/knocking?
How do you know it running lean? Hookup an AF meter?
Will hook up af meter and report findings. Going to chase long finned tuna right now. thanx r.t.
