gtc gtc is offline
abides.
gtc's Avatar
Question about Upgrading the 1984 Fender Oil Cooler
Does the radiator style oil cooler used in the '85+ 911s just swap in for the 28 row brass cooler on the '84, or do I need to replace some of the oil lines and brackets?
Graham
1984 Carrera Targa
Old 02-21-2011, 03:41 PM
Jeff Alton's Avatar
why replace the cooler? The 28 tube cooler you have is superior in a street environment than the later cooler....
Cheers
www.turn3autosport.com
Old 02-21-2011, 05:22 PM
gtc gtc is offline
abides.
gtc's Avatar
My oil temps are fine during most normal driving, but they get too high in bad traffic and when I'm driving spiritedly on tighter (slower) roads.
I have thought about installing a cooler scoop to direct air to the cooler from either the fog or marker light opening, but that wouldn't help in traffic.
Graham
1984 Carrera Targa
Old 02-22-2011, 02:36 PM
Bill Verburg's Avatar
The plumbing swaps over, don't know about mounts but they sure look the same
Bill Verburg
Old 02-22-2011, 02:44 PM
I've added a 7.5" SPAL fan on my previous 85 that had the radiator style....forcing a movement of air over the tube style ( '84) may also be good but maybe not as effective. If it only seems sub-par at idle or slow traffic.... it would seem to respond well to a fan too. Fairly cheap compared to your other possible options.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 02-22-2011, 02:52 PM
Senior Advisor
James Brown's Avatar
I think a fan is all you need. with a switch so you can control the temp in slow traffic. That is a easy fix.
08 Cayenne Turbo
Old 02-22-2011, 03:04 PM
gtc gtc is offline
abides.
gtc's Avatar
The fan might work in traffic, but I'm not convinced it would help at speed.
I haven't seen any figures for the brass cooler's heat rejection, but I have no doubt that the radiators beat them easily as soon as you get some appreciable airflow.
Buying a fan for $75 and a cooler scoop for $90 brings me pretty darn close to the $215 cost of the repro Carrera cooler (Tasker brand, via Pelican).
Graham
1984 Carrera Targa
Old 02-22-2011, 04:42 PM
The finned cooler w/o a fan is pretty terrible. The fan should be wide enough to push a good amount of air, so you feel it coming out hot on the other side. It's a tight fit in there. Most likely you will need to buy or make some mounting brackets, or move the horn.
Old 02-22-2011, 05:28 PM
jwakil's Avatar
I did the upgrade you are considering. As with everything, the first time you do something it is a lot more work than you figured. Getting those short oil lines on and off the copper pipes and the cooler itself can turn into quite a b-tch. Makes it easier if you have two people, one to align the pipes and the other to screw the nuts. Otherwise you can get them stripped. You will need to rig up some kind of a bracket for the top of the cooler. That's the only thing that's really different as far as mounting. The fan is definitely needed when stuck in traffic. Without the fan, you are not much better than the brass cooler. I got a cheap generic one that works pretty well. Luckily it had two mounting points that matched up with the edge of the cooler.
If you have vacuum retard on your distributor, I would suggest disabling that first to see if your idle temps go down. I think that made a bigger improvement for me than the cooler upgrade. The air scoop alone is not going to do much of anything.
82 - Austin Mini 998
78 Mini 1275cc -totaled
83SC Euro w/77 3.0 Carerra Eng.--sold
Several other daily drivers not worth mentioning...
Old 02-22-2011, 06:07 PM
Diss Member
Quicksilver's Avatar
Unless it is a turbo all of the 84 and later cars are Motronic. The computer does all the timing so there are no hoses to the distributor.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-23-2011, 01:12 AM
Member 911 Anonymous
DRACO A5OG's Avatar
I added an Elephant Racing fan with adjustable thermal switch to kick in right at the 190 degree mark on the Oil Temp Gauge.
It helped in stop and go traffic ( and waiting in in drive thru with A/C on during summer ). I know your set up is not the same but what I did from suggestion from a well known member here is to add plastic liner from a spare wheel well liner at the bottom so the forced air will not just blow out the bottom. Just cut to shape and drill holes and use the mounting bolts at the bottom to hold in place. No other mods.
You could do what my buddy did and remove the side marker and fab a mesh (sprayed painted black ) in place and it will at like a less direct scoop at speed and if you ad a fan allow more air to flow in.
At speed no effect, the rear oil cooler works perfectly well.
Jim
'85 Carrera Targa
PCA/POC
Old 02-23-2011, 01:57 AM
Since the original poster specifically said there was a problem in traffic or not-moving conditions, it implies all is well...or at least OK...while moving. That suggests that air flow has a positive effect. Therefore a fan might not be a bad idea to try at low cost.
If you do, suggest using a manual , lit switch to activate the fan...you have more control that way. There is a cut-out on your dash already there normally used for a rear wiper switch....just "feel" for it ! Best also to wire-in a relay. Here is what I did--->
Wil Ferch
Old 02-23-2011, 08:09 AM
I also did this.....a bit more involved than it looks.
- inverted and mounted front signal housing to the side. Inserted a wire harness that I made, inside that module.... per Daniel Stern lighting instructions....to make for a "blinking" side marker light. Uses the external male spades on that housing to feed wires to the "side-marker"....but side marker light is now mounted to the front.
- used Porsche Euro side marker and placed in front, instead of normal side marker, to make a forward-visible blinker... and is a smaller size that allows more direct air flow to the oil cooler. This front light gets power fed from the external spades on the other light pod now moved to the side.
- cut up old rear deck grill... for the grill here...some fab work required to mount a small sheet metal holder.
- removed trumpet horns that block air flow to the cooler, and used "puck" horns mounted lower.
Wil Ferch
Old 02-23-2011, 08:23 AM
Actually....gives a nice impression of both a long hood and short hood car, with the grill used for the long hoods--->
Wil Ferch
Old 02-23-2011, 08:30 AM
Flat Six
Flat Six's Avatar
Dang, Wil -- nicely done. Looks over-engineered (a big compliment in my book!).
Are those two plugged holes in the hood just above the front plate? What are/were they for?
Dale
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 02-23-2011, 09:03 AM
Of course over-engineered...because it was a hobby-project...not a paying job ! ( LOL ! ). I love noodling on my car.
Ahh.....I tell people the two little grommets on the hood are for the removable Cibie Oscars, and they all walk away nodding. Truth?.....one covers a nasty scratch and the other is placed in the mirror-image location to make it seem like grommets. Only a piece of vinyl that avoids a respray to an otherwise near perfect paint job elsewhere.
And before anyone asks...yes, those are flamethrower driver lights ( Cibie 35's ) down below to get rid of those awful useless fog lights.....
Wil Ferch
Old 02-23-2011, 09:17 AM
Flat Six
Flat Six's Avatar
Looks like they could melt snow & ice on the road ahead
Dale
Old 02-23-2011, 09:27 AM
Northern Motorhead
wildcat077's Avatar
Hey Will,
Congrats on post 10,000 and that nice looking air scoop
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
gtc gtc is offline
abides.
gtc's Avatar
Wil,
Thanks for sharing. Your switch is set up exactly how I had planned.
I guess I will just have to buy a cooler to see what bracketry will be needed. It sounds like my oil lines will work, so that is a plus.
Graham
1984 Carrera Targa
Old 02-23-2011, 09:55 AM
Glad to help...man, gotta stop posting so much....or maybe start with a new Pelican name
Double edged sword.....poor business means allowing more time to post here...also means business was bad enough to help with the decision to sell that car. Miss it.
Wil Ferch
Old 02-23-2011, 09:58 AM
