Send a message via AIM to FirstGen
Steering shimmy part 2 - Help!
Well this is my second time to post about this problem I have with my 911. From around 55-65mph I have a very distinct steering wheel shimmy or vibration. The steering wheel shakes enough to where it shakes your arms when it is at it's peak.
Steps I have taken to try and fix this problem:
Replaced all four tires.
Balanced and re-balanced all four tires several times.
Replaced R&P.
Aligned car several times.
Checked front wheels for run-out with a dial indicator (+/- .030")
Checked for anything loose in front suspension, tie rods, wheel bearings, etc.
Still I can not get this dang shimmy to go away. I am pretty much out of ideas with out just throwing more money away on this issue.
At this point I guess my next step is to replace the tie rods with TTR's?
There is no slop anywhere that I can find. All bushings appear to be in good shape.
The problem does not go away or get worse if you turn at that speed or brake the car.
ANY IDEAS?!?
Car is a 1977 911S with 930 flares. Wheels are WORK in 18x8.5 and 18x10.5 with 245 45 18 and 315 35 18 tires. Car is lowered. Has 22/28 t-bars and carrera sways.
Old 09-18-2006, 06:18 PM
GBStu's Avatar
FisrtGen,
I had the same problem at ~65mph with my 79SC; after changing the sway bar bushings this weekend the problem has been solved.
Note, I originally thought the wheels were out of balance, but when they were checked they were spot on.
Hope this helps
Stu
Old 09-18-2006, 07:16 PM
Haven't tired that yet but I really don't know how that would cause that? Glad you found your problem though!
Old 09-18-2006, 07:26 PM
Jeff Alton's Avatar
Are your tires feathered at all from a previous mis alignment. The first, or next thing in your case, I would do is borrow a set of front wheels/tires from someone in your area (with a car that does not shimmy) and bolt them on and see what happens.
Might only cost a case of beer.
Cheers
www.turn3autosport.com
Old 09-18-2006, 09:18 PM
Tires look very normal...
Yeah, I just need to find someone now. I've been thinking about that for a while...
Old 09-18-2006, 10:53 PM
Immature Member
dentist90's Avatar
I've got same problem.... fine at lower speeds but shakes at speeds over 60 mph. Felt just like a balance issue but wheel balance checks out to within 1/2 ounce. I have readjusted bearings on both sides and checked tie rods. It's tight under there ( I guess thats why vibration comes thru steering wheel SO well).
Turns out that I've flat-spotted both front tires ( my bad!) and my 'tire guy' says that could do it. Usually you would just feel a light thumping in the steering wheel that just gets faster with speed. But apparently if the flat spots on each side get on opposite sides of each other it can set up a harmonic up and down and come back thru the steering wheel. Anyway, new tires on the way. Did you try spinning your tires with some sort of indicator against the tread to see if they're truly round? New tires shouldn't have this problem, though. I know my 30' skid on warm tires didn't do them any good.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 09-19-2006, 07:59 PM
well I just ruled that out when I had brand new tires put on and on the way home it did the same thing...
Old 09-20-2006, 07:08 AM
Jon Merck's Avatar
First Gen check your hubs on the back side.
I have the exact problem in my car. When I pulled the hubs off the front to upgrade my brakes I noticed a lot of buildup from 30 years of road grime and brake dust. Some places it was 1/4" thick!
I won't be able to determine if this is causing my problem until I get my engine in, but it seemes like this could be a possible cause...Hope this helps.
Jon
Old 09-20-2006, 11:36 AM
FSTNBLK check your PM's...
Old 09-20-2006, 12:10 PM
450knotOffice's Avatar
FirstGen, do you have wheel spacers, per chance? I've heard those can cause vibration issues. It's been documnted on this board.
Old 09-20-2006, 12:14 PM
pmajka's Avatar
Yeah, if you have spacers, clean the wheel adn spacers and Hub....I used light steel wool
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 09-20-2006, 01:20 PM
I use to have wheel spacers but I have since removed all spacers on the car in an effort to get rid of this problem. Didn't help any...
Old 09-20-2006, 01:53 PM
pmajka's Avatar
what about play in the steering rack????
88 Carrera
Old 09-20-2006, 04:39 PM
Try Mark Wilson and efhughes3. They are both Dallas area Pelicans.
Old 09-20-2006, 05:14 PM
I had the exact same problem with my 73.5. After checking balancing and front suspension parts, an (expensive) alignment got rid of every bit of the shimmy. Are you sure your alignment was a good one?
Ken
Old 09-20-2006, 05:26 PM
Already replaced the rack with another good one so no dice...
Old 09-20-2006, 05:32 PM
Ken
Pretty sure, at this point I'd be willing to try just about anything. It wasn't done through the dealer however.
Old 09-20-2006, 05:34 PM
Jon Merck's Avatar
PM's checked
Jon
Old 09-20-2006, 05:37 PM
Loose nut bhind the wheel
I had to replace the u-joints in the steering column on mine to get rid of my shimmy. When I removed them they were notchy when they were articulated. The new ones were smooth. I would first borrow a set of front Fuchs with good tires to test on it. you replaced the tires but the wheels are the same. Might also put on new brake rotors. At this point it is a crap shoot and you have just about replaced everything else. Good luck with it.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 09-20-2006, 08:35 PM
Yeah, I really wish I had a set of front wheels to try so that I could narrow that as the culprit out...
Old 09-21-2006, 08:16 AM
