Steering shimmy part 2 - Help!
Well this is my second time to post about this problem I have with my 911. From around 55-65mph I have a very distinct steering wheel shimmy or vibration. The steering wheel shakes enough to where it shakes your arms when it is at it's peak.
Steps I have taken to try and fix this problem: Replaced all four tires. Balanced and re-balanced all four tires several times. Replaced R&P. Aligned car several times. Checked front wheels for run-out with a dial indicator (+/- .030") Checked for anything loose in front suspension, tie rods, wheel bearings, etc. Still I can not get this dang shimmy to go away. I am pretty much out of ideas with out just throwing more money away on this issue. At this point I guess my next step is to replace the tie rods with TTR's? There is no slop anywhere that I can find. All bushings appear to be in good shape. The problem does not go away or get worse if you turn at that speed or brake the car. ANY IDEAS?!? Car is a 1977 911S with 930 flares. Wheels are WORK in 18x8.5 and 18x10.5 with 245 45 18 and 315 35 18 tires. Car is lowered. Has 22/28 t-bars and carrera sways. Last edited by FirstGen; 09-18-2006 at 06:22 PM.. |
FisrtGen,
I had the same problem at ~65mph with my 79SC; after changing the sway bar bushings this weekend the problem has been solved. Note, I originally thought the wheels were out of balance, but when they were checked they were spot on. Hope this helps Stu |
Haven't tired that yet but I really don't know how that would cause that? Glad you found your problem though!
Are your tires feathered at all from a previous mis alignment. The first, or next thing in your case, I would do is borrow a set of front wheels/tires from someone in your area (with a car that does not shimmy) and bolt them on and see what happens.
Might only cost a case of beer. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Tires look very normal...
Yeah, I just need to find someone now. I've been thinking about that for a while... |
Immature Member
I've got same problem.... fine at lower speeds but shakes at speeds over 60 mph. Felt just like a balance issue but wheel balance checks out to within 1/2 ounce. I have readjusted bearings on both sides and checked tie rods. It's tight under there ( I guess thats why vibration comes thru steering wheel SO well).
Turns out that I've flat-spotted both front tires ( my bad!) and my 'tire guy' says that could do it. Usually you would just feel a light thumping in the steering wheel that just gets faster with speed. But apparently if the flat spots on each side get on opposite sides of each other it can set up a harmonic up and down and come back thru the steering wheel. Anyway, new tires on the way. Did you try spinning your tires with some sort of indicator against the tread to see if they're truly round? New tires shouldn't have this problem, though. I know my 30' skid on warm tires didn't do them any good.
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
well I just ruled that out when I had brand new tires put on and on the way home it did the same thing...
First Gen check your hubs on the back side.
I have the exact problem in my car. When I pulled the hubs off the front to upgrade my brakes I noticed a lot of buildup from 30 years of road grime and brake dust. Some places it was 1/4" thick! I won't be able to determine if this is causing my problem until I get my engine in, but it seemes like this could be a possible cause...Hope this helps.
Jon |
FSTNBLK check your PM's...
FirstGen, do you have wheel spacers, per chance? I've heard those can cause vibration issues. It's been documnted on this board.
Yeah, if you have spacers, clean the wheel adn spacers and Hub....I used light steel wool
Have you ever felt suffocated while watching the Oxygen Channel? People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself. 88 Carrera |
what about play in the steering rack????
Try Mark Wilson and efhughes3. They are both Dallas area Pelicans.
I had the exact same problem with my 73.5. After checking balancing and front suspension parts, an (expensive) alignment got rid of every bit of the shimmy. Are you sure your alignment was a good one?
Ken |
Pretty sure, at this point I'd be willing to try just about anything. It wasn't done through the dealer however. |
PM's checked
Jon |
Loose nut bhind the wheel
I had to replace the u-joints in the steering column on mine to get rid of my shimmy. When I removed them they were notchy when they were articulated. The new ones were smooth. I would first borrow a set of front Fuchs with good tires to test on it. you replaced the tires but the wheels are the same. Might also put on new brake rotors. At this point it is a crap shoot and you have just about replaced everything else. Good luck with it.
Ed 1970 911S Targa 2.7RS MFI dual plug 10.5:1 1974 260Z SCCA ITS 1998 M3 Last edited by eapcpa; 09-21-2006 at 09:16 AM.. |
Yeah, I really wish I had a set of front wheels to try so that I could narrow that as the culprit out...
