Another rebuild or replace thread
Just spoke with my mechanic after having dropped my 3.0L off to figure out why the #5 cylinder was dead. Turns out 35% leak on #5 and #6 and damaged cam lobes. The motor has 120K on the clock and it needs some serious work.
I can rebuild it here at home, with the help of my mechanic, however the car is not a perfect specimin to begin with. The interior is good, fresh seats, nice carpet and door panels, paint is a 5 out of 10 respray job in silver. No dings or dents or the such. So should I rebuild the top end? Or replace with a used 3.0L? Or 3.2 for that matter.... My motor is EFI, with upgraded tensioners, so I have parts I can transfer. What to do?
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
DIY. Did he say why it leaked. Head studs? Broken rings? Bent valves?
You gonna sell the tbitz if you get a 3.2?
78SC coupe, Silver Metallic |
And no, I'll never sell my TBITZ, thet system is just to good to get rid of. Even if I went 3.2 I would keep it.
Senior Member
I wouldn't put a used 3.2 in it. I'd rebuild the 3 liter, to 3.2 specs if I had to replace the jugs......or I'd drop in a 3.6.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Ok, ordered a bunch of tools tonight from our host, yoke and etc, things I did not already have. Will tear into this weekend, thanks again guys.
I have some new 98mm RSR jugs for sale in the classifieds. Perfect for your application!
John Brasfield 91 C2 78 SC For sale 76 3.6 68 Datsun 2000 Mr. Magoo, 02 330ci |
