Banned
993 brake question
Ive located a full set of rotors and black 4 piston calipers from a 993 car for install on my 84 coupe. Someone said these wont work with Fuchs. Is this correct and what will I need for install. Mark
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
Front
993 calipers w/ caliper adaptors and either 993 rotor on a 911 hub or '78-80 930 floating rotors and hats or aftermarket rotor/hat 951 7 Fuchs w/ spacer, 951 8" Fuchs or aftermarket wheel Kinesis, Fikse, etc Rear 965 rear calipers are better but 993 rear can be modified to work, 993 rotors won't work here(unless modified, this is not a DIY), use '78 up 930 rear rotors. 911 8" Fuchs w/ spacer, 930 9" Fuchs or aftermarket 9"
Banned
brake upgrade
Bill, Can you verify that these are 993 calipers and rotors? Ive got a set of SC hubs and a set of 944 hubs too. Which would be best? Thanks, Mark
They look like 993 parts
