DUK DUK is offline
DUK's Avatar
993 Caliper/ Rotor Adapter is here.
Promised a while back that I would post pics when we were finished with these, well here they are. Thanx to Bert Beagle, We've got the adapters finished and I must say they look fantastic. Still got to figure out the brake line, not sure I like this layout, any ideas? BTW these are '95 993tt Calipers and rotors. Read further...
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 09-29-2006, 04:57 PM
BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
MMM sexy. That sure is an interesting way the caliper bolts up the strut. Kind of an improvement in size over your old M's, eh?
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 09-29-2006, 05:43 PM
efhughes3's Avatar
I'd make a hard line and bolt up to the flex line at the strut, like stock. While mine isn't as shiny as yours, here's a pic:
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Ed is right,...
That prevents a long flex line from interfering with the swaybar arms when the wheels are turned. BTDT, and thats a real pisser when the SS line gets torn loose,............
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-29-2006, 05:56 PM
beamonk's Avatar
Send a message via AIM to beamonk
What hubs are used? I just turned down an old 911 hub for testing, rumor is the proper hub is a 944. Are the adaptors commercially available?
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 09-29-2006, 06:20 PM
DUK DUK is offline
DUK's Avatar
Tom- Yea these are much bigger and more noticeable. How's your project coming?
John- I'm using turned down 911 hubs, they seem to have enough material still so I'm not too worried. The adapters are available at Pro-systems braking 704-799-8100 ask for Ashley.
2000 & 2007 Dobies
Old 09-30-2006, 04:16 AM
Senior Member
Looks very nice!
Old 09-30-2006, 04:55 AM
Bill Verburg's Avatar
Looks good, I wouldn't run the brake like like that either.
You will need 993 or 965 calipers on 930 rotors in the back as well, unless Ashley can come up w/ an off the shelf Brembo w/ ~30/34 pistons that will accept a 309x28mm rotor.
ps I edited the original post to get a better presentation
Bill Verburg
Old 09-30-2006, 05:02 AM
DUK DUK is offline
DUK's Avatar
Thanx Bill, Yes were going with 993 rear calipers and 930 rotors. I'm really looking for a good way to do the front line, any ideas or pics? Thanx, Duke
2000 & 2007 Dobies
Old 09-30-2006, 02:58 PM
On second look that caliper does not appear to be a 993 caliper. It looks to be a 993tt caliper. The rotor does look llike a 993 front rotor. If so the caliper is not a good fit for the rotor. True 993 front calipers will use the same adaptor.
Bill Verburg
Old 10-01-2006, 07:55 AM
DUK DUK is offline
DUK's Avatar
Bill, I'm confused again. These calipers seem to be 993tt but the 993 c2 pad works in them. Are the tt calipers wider? What issues do you mean as far as fitment to rotor?
2000 & 2007 Dobies
Old 10-01-2006, 11:17 AM
The tt pad is a few mm taller, and does not have the holes for a pad puller
In this pic far to near, 993tt front, 993tt rear(same as n/a 993 front), 993rear(same as 964 f/r and 930 f/r)
Bill Verburg
Old 10-01-2006, 11:31 AM
DUK DUK is offline
DUK's Avatar
we'll have to look closer at this, the 993 c2 pads fit perfect and the tt pads don't seem to, as they are too tall. Could you measure a tt caliper pad area? maybe from the striker plate bend to the top of the pad area? Mine measures 65mm. Thanx again and sorry to be such a bother, Duke
2000 & 2007 Dobies
Old 10-01-2006, 11:55 AM
You can differentiate between the 2 calipers by the raised knob above the lettering and on the outside edge of the pad box on the tt
993
993tt, 993RS, aka Big Red
Bill Verburg
Old 10-01-2006, 12:34 PM
DW SD's Avatar
Duke,
Did you turn down the hubs so the rotors can slip over?
Looks good!
Doug
1971 RSR - interpretation
Old 10-01-2006, 04:51 PM
randywebb's Avatar
Originally posted by Bill Verburg
Where's the rug?
And, have you been acid staining your garage floor??
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-01-2006, 05:00 PM
Porsche-pa
75Carrera's Avatar
Looks really sweet Duke. Bill sets the bar high but I like what you're doing with those 993 rotors. Were they hard to find? I wonder if anyone has ever tested (stop distance) the difference between a stock Carrera alloy brake and the 993's? I would think it would be a substancial gain, eh?
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 10-01-2006, 05:06 PM
Will Fuchs work with that setup?
Old 10-01-2006, 06:06 PM
Originally posted by 75Carrera
Looks really sweet Duke. Bill sets the bar high but I like what you're doing with those 993 rotors. Were they hard to find? I wonder if anyone has ever tested (stop distance) the difference between a stock Carrera alloy brake and the 993's? I would think it would be a substantially gain, eh?
They do generate a lot more torque, you should have stickier tires to take advantage because the tire is usually the weak link in that department.. But the biggest benefit is in thermal capacity. The brakes run cooler and thus longer.
Bill Verburg
Old 10-01-2006, 06:34 PM
944 8's or better are needed for the front
Bill Verburg
Old 10-01-2006, 06:37 PM
