WydRyd's Avatar
Question Carrera Guys: Good 12v source in engine bay?
Anyone know of a good stable 12v source (in engine bay) when the engine is cranking / running only?
Looking for a feasible point to power an electric oil scavenge pump, if I decide to go down that route.
I don't want the pump running whenever the ignition is turned to Accessories.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-26-2006, 10:21 PM
len911's Avatar
If I remember correctly, on the drivers side, behind the back plastic cover with the single wing nut, you can tap into one of the fuses there. I believe there is 3 of them. One is for the aux heater fan in eng compartment, the other is for the rear defroster, and I think the last one is for a Sportomatic... Just use a voltmeter to check for voltage. Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 09-27-2006, 04:38 AM
WydRyd's Avatar
OK thanks, I'll check it out
Merv
'89 911 Turbo Cab
Old 09-27-2006, 06:18 PM
Merv,
Here's the layout from the owners manual....
Warren & Ron, may you rest in Peace.
Old 09-27-2006, 08:24 PM
