Somewhere in the Midwest
MotoSook's Avatar
951/964 Front Caliper Install on 911...?
I've seen a couple of ways to install the 951/964 calipers on a pre-89 car w/regard to the fluid line, but I haven't seen anyone (none that posted yet anyhow) simply use the 951 hose to go from the caliper to the hard line on the chassis. I haven't started unbolting things yet, but it appears that the stock 951 hose may be long enough to do the job.
Anyone gone down this exact route yet? Any issues?
Old 09-27-2006, 08:12 PM
MotoSook's Avatar
Bump for the day crew.
Old 09-28-2006, 07:04 AM
MotoSook's Avatar
Com'on boys...I can't be the first to have thought of something so stupid
Old 09-28-2006, 10:53 AM
Jon Merck's Avatar
Souk, I used my existing lines (braided stainless) and rebent the hard lines. I could not route thru the loop welded on the strut. Everything was too short, so I plan to weld a clip for my new configuration if I have any problems.
I will try to get a picture of what I did and post it.
Hope this helps!
Jon
Old 09-28-2006, 11:28 AM
MotoSook's Avatar
That helps Jon. If I don't have a heart attack trying to fit 3 days into one day today, I'm going to get the car on the lift when I get home and get greasy. I'll know if the 951 line will suffice, else I'll give your method a shot...or the otherway around. Thanks.
Old 09-28-2006, 12:21 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The ideal thing is to have custom flex lines made. Next best is custom fitting your own hard lines and that involves flaring which can be a PITA. Last and easiest is to buy pre-length hard line already flared with tube nuts. That's what I did with little difficulty. Only hangup I found was 8" is a bit too short and 12" is a bit too long. I'll shoot a picture of some of my iterations.
I didn't feel comfortable re-bending the existing A caliper hardlines. But Bernie hasn't died yet and that's what he did. Original lines are easier to bend because it seems like they're softer metal. The parts store lines are prettty darn stiff compared to the originals.
Kevin L
'86 Carrera "Larry"
Old 09-28-2006, 01:40 PM
MotoSook's Avatar
The 951 flex line is pretty long, I'm thinking it's 12-14 inches long, almost twice as lone as the 901-XXX-XXX-XX part number hose/line.. I happen to have a used one that came with one of the calipers I bought for machining. I did a preliminary check last night...and I'm hoping it's all I need (just the 951 line from the caliper, and no new hard line). I'm gonna be all over the place for work before the Octoberfest DE, and I don't have time to be fooling around with bending or flaring tubing
I'll give you the keys to the garage and leave out lots of food if you want to come work on FB while I'm gone K-man.
Old 09-28-2006, 02:01 PM
efhughes3's Avatar
I bought straight (pre-flared) lengths of hard tube @ NAPA.....They came in several lengths. I think I ended up using 12 inchers. Bending was really pretty simple and only took about 10 or 15 minutes per side.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-28-2006, 04:02 PM
hmd hmd is offline
Same here.
76 Carrera 3.0 (Group Sc)
Old 09-28-2006, 04:06 PM
MotoSook's Avatar
So you use the stock short hose (part number 901-###-###-##) and the Napa hard line? Right?
Old 09-28-2006, 04:11 PM
efhughes3's Avatar
The Napa hard lines are available in metric sizes which hooked right into the soft lines. I happen to have braided S/S, but they are the same size fittings as stock. It really worked well. Let me see if I can dig up a pic...
Ed Hughes
2015 981 Cayman GTS
Old 09-28-2006, 04:16 PM
MotoSook's Avatar
A pic would be great, Ed.
Here is what I'm thinking (the diff in hose length and ends).
With the 951 part, I don't need the hard line.
Old 09-28-2006, 04:26 PM
efhughes3's Avatar
Here's the only pic I could find, but it gets the point across. I'm pretty sure these were 12" long pipes to start with. I got 10's too, IIRC, but they were too short. I see what you're getting at, but the question that comes to mind is: Why do you never see flex lines going to calipers? Is there a reason why there is always (to my knowledge) a flex line between the chassis and a hard pipe going to the caliper?
Ed Hughes
2015 981 Cayman GTS
Old 09-28-2006, 04:38 PM
MotoSook's Avatar
That's a pretty clean installation Ed. Thanks for the pic.
I suppose the less soft line there is, the less chance of debris damaging the line. The only reason for the soft line is for steering and suspension travel...just enough, but not tooo much to allow it. Plus, less soft lines, means less expansion.
Old 09-28-2006, 04:43 PM
Jon Merck's Avatar
Souk,
Here is the front using existing tubing off my 77
Here is the rears
Note: I have not road tested these yet but, I feel confident that they will hold up...
Jon
Old 09-29-2006, 01:14 AM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Jon, you know I need more pictures of your caliper installation......and to know what rotors you are using.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 09-29-2006, 05:47 AM
Bill Verburg's Avatar
You do
But the flex capability isn't needed between the caliper and the strut, I think that it is a neater to use a hardline in that section.
Bill Verburg
Old 09-29-2006, 06:10 AM
MotoSook's Avatar
Thanks for the posts guys. I'll down a shot of rub with get a bucket of Original Recipe from KFC while I'm on the road, so that no bad mojo befalls me when I start ripping into this the night before my DE.
Old 10-01-2006, 08:00 PM
