Bill Klima
Guest
Posts: n/a
checking timing
can anyone tell me how to check and adjust the timing on a 79 3.0 911 thanks Bill
Old 07-03-2000, 04:04 AM
Superman
Guest
Posts: n/a
There is a sticker in my car, on the inside of the deck lid, that give the timing specs for my car. Yours may be different.
When I remove the vacuum hose, the idle rises, so then I have to adjust the idle back down to 900 to check timing. When I'm done and I reattach the vacuum hose, idle drops and I then have to increase the idle back to 900.
In the meantime, with idle at 900 and vacuum hose disconnected, timing should be at 5 degrees BTDC. Your car's spec may be different.
'83 SC
Old 07-03-2000, 11:37 AM
