pjv911's Avatar
Send a message via AIM to pjv911
Who has a 3.3 cis turbo pre 73` car ?
I need some hands on experiance for some of my questions regarding my project. I am putting a 1992 C2 turbo motor in a 1969 coupe. I am presently aquiring(trying anyway) the fuel system components. I see that the pre 89 turbo cars use a different pump combination due to different part #`s . Is there actually a difference ? Will any CIS type fuel tank with a return line work ? What fuel line diameter do I need to use ? I have alot more questions and would love to find someone who knows what I need. Any help would be much appreiciated.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 10-26-2003, 11:08 AM
pjv911's Avatar
Where`s the love guys ? This board seems dead these past few months.
Old 10-26-2003, 12:02 PM
Kurt
In my car I used the stock front SC fuel pump. In the rear I bought a turbo fuel pump. I don't remember what year pump I got. I don't think it matters. I think it you put an aftermarket pump up front it would work fine. As long as you have enough flow and pressure. The motor doesn't care. A purist might. If I did another conversion I would do the aftermarket pump up front. I used 5/16" lines. Very close to 8mm
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 10-26-2003, 12:17 PM
pjv911's Avatar
Thanks dean. BTW did you simply retain your stock fuel tank ? Also if you think it makes any difference , I just bought a Euro CIS unit which flows more fuel. Do you think the stock 75-89` pumps will flow enough. I figure it would. I dont plan on going past 1 bar of boost anyway. But then ???
Kurt Williams
Old 10-26-2003, 12:45 PM
Crotchety Old Bastard
RarlyL8's Avatar
You should be fine. My SC/930 conversion also retained the stock pump up front with a 930 pump rear. Stock tank. Engine has the usual 930 mods that put it close to 400hp at the crank. No fuel starvation.
RBoylan of Florida has done an early 911/930 swap. Rattlesnak in Atlanta has done an SC/CT2 swap. Both should be able to help you.
Old 10-26-2003, 03:01 PM
Kurt,
I also used the stock tank and front fuel pump. It was a pain to wire the rear pump because I did it like the factory did. I also don't think the euro CIS is that different. If you are not a purist then put an aftermarket EFI fuel pump up front. My motor is running lean now but I don't think it is the fault of the fuel pumps. It is more likely the CIS.
Dean
Old 10-26-2003, 03:56 PM
pjv911's Avatar
Thanks guy`s now how about the oil tank ? Did you use the 930 type sump tank(in the rear quater panel) with the extra return fitting or just plumb one into the existing tank ? Also my motor package came with a hoard of aftermarket performance parts which included about 10 wastegate springs. I can see differences in colors and thicknesses. Is there a way to tell which is which without trial and error. Of course for starters I will use the original which is on the motor. I have extra wastegate assemblies too and would like to set up one of them for an easy swap once the engine is ready for more boost. Also one of the wastegates has a threaded adjustment screw on the top and the others(including the one on the motor) have a hose fitting. Whats the deal there ?
Kurt Williams
Old 10-26-2003, 04:08 PM
For the oil tank-I brazed a piece of brake line into the top of the oil tank for the return. That is basicly what the factory did. I don't know what to say about the springs. Trial and error sounds good I test wastegates with a gauge and a pressure reg. on the bench. There you can see exactly where they are opening. I don't know about the screw on top of the wastegate. Maybe it is a way to preload the spring for more boost. The hole in the top is a vent for the diaphram
Dean
Old 10-26-2003, 06:07 PM
dozer's Avatar
I've heard there is a difference (car 911SC-1978/enginen 930-1983) between the 16 pin conector in the engine bay. Does annyone know?
Or is there annything else thats different from 78'SC-83'930 eletrical.
"It gets a little bit louder above 5,000 RPM so you can't hear the passenger scream"
Porsche 911 Turbo
Old 10-10-2006, 11:11 AM
rboylan's Avatar
Cool Been there, done that .
Gimme a ring if youd like to chat. Thanks.
Rich Boylan
561 512 5185
2014 911 GT3
1979 930 Turbo
1970 911T
2016 Cayman
2019 Macan
Old 10-10-2006, 11:49 AM
dozer's Avatar
Hi Rich!
Tryed to call you... only voicemail.
Would it be possible for you to send me a mail on "how to" ??? (Or even better, post it here)
It would be greate help!
Thanx
Please mail to: rottis(at)online.no
Porsche 911 Turbo
Old 10-11-2006, 05:27 PM
7.0:1 > 11.3:1 > 7.0:1
Regarding waste-gates, I can't give you advice on your specific sprigs, other than to say that if the spring has a lesser rate (lb/inch) it will give you a lower boost thresh hold. Testing on the bench would be most easy to determine this in advance via a regulator as previously mentioned.
The waste-gate diaphragm cover which has a bolt or set screw with a jamb-nut allows you to increase your boost set-point by tightening down the spring.
The waste-gate cover with a hose is intended for adjustable boost by means of running a line from your boost charge pipe to a regulator, then back to the waste-gate cover. This effectively applies extra pressure to the top side of the diaphragm similar to the adjustable set screw, only the regulator allows you to make these adjustments remotely.
Jim
79 930
Old 10-12-2006, 10:40 AM
dozer's Avatar
Annyone???
Porsche 911 Turbo
Old 10-13-2006, 10:12 AM
