please help with exhausting problem
I have a 76 911s with an ,84 3.2 with triad heat exchangers and a triad 2 in 2 out muffler. About a year ago the exhaust smell from this engine became very strong and noxious. It is a very strong exhaust smell not gas or rotten eggs. It comes inside the car with or without the heater being on and when stopped at stop lights the car is enveloped in exhaust. Is there any way to tune the car to decrease the smell. Will a chip help. How do I check the heat exchangers for leaks. What else can I do.
1976 3.2 911s cabrio slantnose |
"O"man(are we in trouble)
Sounds as though your HE's are leaking and exhaust is coming into the car. I wouldn't want to mess with that if that is the problem. I don't know how you would check the inside pipes, you could place a CO detector card in the car, close it up and let it idle (without anyone in the car). Wouldn't take long to determine if you had a leak.
I wouldn't take any long trips with the windows closed. |
You could try process of elimination, starting with a new gasket kit from the HE's to the muffler. Easiest and most inexpensive first.
If that doesnt resolve the issue, start removing the muffler system and HE's, with a whole fresh gasket set. Be prepared to deal with broken HE studs...Thats the part widgeon13 said he wouldnt want to mess with. I concurr...
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I suspect that you may end up having to replace the HE's.
triad west does not make heat exchangers. the final exhaust bolts to the heat exchangers
Re: please help with exhausting problem
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
