Strange 911 steering problem
I'm the new owner of a 1988 911 Cab and have an unusual steering problem. The problem is that in slow (10 mph or less) sharp turns, the front of the car bumps from side to side, but makes no unusual noises. Visual inspection of the front-end reveals no bent items or recent work. Wheels bearings good, wheels straight, car drives straight, and tire wear appears normal. Any ideas? Thanks in advanced, Will
It could be the tires. Sometimes separation of the plies will cause the tread to move side-to-side under extreme turns. This would not be outwardly visible on the tires.
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait! |
Another thought, does your car have posi-tracion? If so, you might be feeling the clutches in the differential doing their thing.
Thanks 930turbo. The tire idea could very well be the problem. Do not have posi-traction. Thanks again, Will
Different toe settings?
Donnie Currently Porsche-less.....
Problem update-
Temporarily swapped rear and front wheels. No help. Playing with the toe adjustment found and that the problem went away with a extreme toe out condition, but the car didn't want to drive straight. I'm now thinking that I might have a "toe difference angle" problem which there is no adjustment for other than replacing defective parts. I have noticed a small amount of play (adjustment/alignment) in the positioning of the steering rack with it's two bolts loosened. My question is this loose positioning of the steering rack normal? |
Re: Strange 911 steering problem
'96 Dodge Viper '09 Maxima '05 zx10..(0-100-0 before your turbo even spools!!) '99 Rottweiler '08 Cane Corso |
Is it possible your rack is not centered while the wheels/steering wheel are? It is possible your rack was setup a few teeth off center.
durn for'ner
Is the front lowered way beyond stock ?
What rim and tire sizes ?
Markus Resident Fluffer Carrera '85 |
Update-
The steering rack is centered. Riding heighth set to factory specs. Front wheel is 6X16 with 205/55 ZR16 tire Rear wheel is 7X16 with 225/50 R16 tire All stock parts |
Confused
Have you checked the universal joints in the steering column?
Mine had a defective joint (old and rusty) that also caused a noise and kind of a bump in the steering wheel due to a pit in the one bearing races of the universal joint. - always at the same angle of steering wheel turn. It was obvious when the car was on jackstands and someone turned the wheel while I had a finger on the joint - clear as daylight.
Squeaky brakes are safer.... 2000 GT3 Clubsport, 1967 911 2.7 Track toy in progress 1983 Lamborghini Countach 5000S, 2009 VW Tuareg, 6 Bicycles - 3 Road, 3 Mountain |
Update-
Steering universal joints check good. Do not have a LSD. When problem occures no sound is made. |
Anything more on this I also have this problem. Inotce it mostly backing ouf or pulling into parking spaces( slow sharpe corners)
Thanks Mark 1986 911 Targa |
Update-
No fix yet. Mine also does it when backing up. Lately I have been suspecting old tires on front and rear causing the problem. Are your tires old? |
I am not sure how old my tires are. I have only had the car about 8 months. I also thought about the tires because I did not notice it until after it started to get colder.
Mark |
You guys with this problem aren't, by any chance, getting tire rub on the inner fender panel? Or something else?
My SC has brake cooling ducting (hardly stock stuff) which restricts how far I can turn the wheel without a tire grabbing it. Feels like what you describe, though I don't recall any of this before I added the ducting (which doesn't really have quite enough room). I just live with it. But this is a long shot for a stock street car. Walt Fricke |
Update-
No tire rub. Problem starts at about half way max steering wheel turn in both directions. |
Has the car been lowered? If so you might want to install the little spacers that raise the steering rack up
Tony Proasi 1969S 1957 VW Pickup |
