sean m's Avatar
What is CIS??
Sorry guys.....I'm still a newby. What is CIS conversion???? I've seen it in several posts, done the search, still don't know what it is.
I've got a 77 911s, 2.7. Just recently put in the 11 blade fan and what a huge difference in temperature that made! I've seen an air box in Vertex and Pelican that said is for the CIS conversion.
I'm still lost. What is it and is it something I need to do?
Thanks for helping out.
Sean
Sean M
'77 911S Targa Ice Green
Old 10-17-2006, 05:03 PM
Oh Haha's Avatar
CIS=Continuous Injection System
In simple terms it means fuel is constantly flowing metered by a valve or meter. It works very well versus carburetors as there is less tuning needed.
Do a search here on CIS and read more info than you can process.
You should have CIS on your 77. It was standard starting in 74. You should get some books on 911's so you can learn as you upgrade/make repairs. 101 Projects for your Porsche 911 is an excellent source of info. A Bentley repair manual is vital to maintaining these cars, if you do the work yourself. Heck, you can understand what your wrench is telling by learning more. Hope this helps and welcome aboard.
Pacific Blue
Wayne
Old 10-17-2006, 05:10 PM
to pick a point - actually CIS started in 73.5 911's.....
Old 10-17-2006, 05:18 PM
Oh Haha's Avatar
Bite me.
Pacific Blue
Wayne
Old 10-17-2006, 05:22 PM
Bollweevil
this should help with your CIS questions:
http://members.rennlist.com/jimwms/CIS/CIShome.html
Jack
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 10-17-2006, 06:24 PM
randywebb's Avatar
I'm lost on the conversion part -- maybe some mentioned converting away from CIS to carbs?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-17-2006, 09:06 PM
FenderGuy's Avatar
Sorry you are wrong it is" Continuous Income Spending” ask me how I know
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 10-17-2006, 09:37 PM
al lkosmal's Avatar
Cranial/rectal Inversion Syndrome
RGruppe #669
http://www.x-faktory.com/
Old 10-17-2006, 09:39 PM
LakeCleElum's Avatar
Thank you!!!!!!
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 10-17-2006, 10:37 PM
I couldn't find anything about a 'CIS conversion' air box on their site. Maybe post a pic of what you are looking at so we have a better understanding of what it is.
Chris
'75 911s Targa
Old 10-18-2006, 04:26 AM
sean m's Avatar
Here is the air box. Anyone installed this? Is the sound different?
Sean M
Old 10-18-2006, 04:42 AM
I believe it's just for aesthetics, no real improvement on anything. I could be wrong and if I am someone will correct me.
Chris
'75 911s Targa
Old 10-18-2006, 05:13 AM
From a number of people who have done this (or something similar) no performance increase, just noisier.
Jerry M
'78 SC
Old 10-18-2006, 05:27 AM
Designer King
Paulporsche's Avatar
A good source for CIS (and other) info is the Bentley Manual for the SC, which covers cars from 78-83. Your system is very similar to that for a 78.
There is also quite a bit of info on this site on this. There are exploded system diagrams in the tech section. There are also numerous entries on various component problems and solutions.
If you search the names of the various components, you will see what I mean.
Most common start/warmup/run faults seem to come from an out of spec or bad WUR (warmup regulator). These can be cleaned, adjusted, made to be more easily adjusted, or replaced.
Oher common maladies arise from a malfunctioning AAR and/or AAV (auxiliary air regulator and valve) or often a bad Decel (eration) valve.
Vacuum leaks and bad or out of adjustment points also contribute to possible run problems.
An out of spec mixture can cause start and run problems. This mixture should be adjusted to compensate for the ambient temp changes that can occur in the fall and spring.
Many members have purchased a CIS fuel pressure gauge to check their fuel and control pressures, which are critical to achieve proper functioning of the system.
You should search first, then post any questions or problems you are having.
Good luck and enjoy the "mysteries" of your car.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-18-2006, 06:06 AM
Unregistered
sammyg2's Avatar
That cover will make you go faster by making your wallet lighter.
Old 10-18-2006, 06:50 AM
Kelly Bell's Avatar
CIS = Constantly In the Shop..............
Kelly Bell
72 MGB
75 911S
00 Volvo S70
Old 10-18-2006, 08:58 AM
19 years and 17k posts...
azasadny's Avatar
Constant Irritation Syndrome...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-18-2006, 09:16 AM
azasadny's Avatar
Cannot Increase Speed
Art Zasadny
www.ford.com
Old 10-18-2006, 09:17 AM
Irrationally exuberant
ChrisBennet's Avatar
Complicate Icky System
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-18-2006, 09:43 AM
Dan in Pasadena's Avatar
Bite me.
Not often I laugh out loud at a thread response. Hilarious Wayne. Perfectly understated, I almost sprayed coffee out my nose!
Sean, that "conversion" IS just a bling thing. Doesn't do a thing to make your car run better. Not that I am entirely against aesthetic stuff...I've done plenty of it to my car. Better to spend the $$ you would have spent on that on (as everyone has said) Wayne's 101 Project book or a Bentley Manual. A MUCH better use of some extra cash if you own a 911.
P.S. SOmeone should post "The Ultimate Acronym Thread" here. These CIS acronyms are hilarious. Cranio-rectal Inversion System is too, too funny.
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 10-18-2006, 09:51 AM
