Cam setting and performance on 3.0l engines
The C3 engine and early SC engines are pretty similar - same intake and exhaust, valve size, cam - with the notable exception of crankcase and crank (Indeed the c3 makes use of the light 2.7 crank). I do not believe that the difference in HP (200hp C3 vs 180hp SC) can come from the lighter crank.
However, C3 and SC do not have the same cam setting : Porsche set a milder cam setting for the sc in an effort to giver better low grunt.
So my question is: do you believe that the performance gap between c3 and sc engines come from cam setting ?
Is it possible to apply c3 settings to a SC engine ?
Mathieu
Old 10-23-2006, 03:30 AM
Bill Verburg's Avatar
Re: Cam setting and performance on 3.0l engines
Mathieu
Partly, but there were also fuel and ignition mappings that were diferent.
The air pump used on SCs was also a drag on performance
and don't forget theC3 used a premuffler w/ an elegant internal shape, the SC used a cat
Lots of little things eventually add up
Can C3 tune be applied to SC absolutly, but I would lok at the '82 and '83 as a better model
Bill Verburg
Old 10-23-2006, 04:43 AM
thank you Bill
Old 10-23-2006, 05:28 AM
