Why would replacing DME result in slight reduction of power?
'87 DME died a while back and the replacement was the newer version with 28 pins. The old DME's chip had fewer pins. Thing is I noticed a slight reduction in power. Puzzling. BTW, both had S.Wong chips, same parameters. The old DME just made the car more powerful in the top end.
Old 10-27-2006, 02:06 PM
DW SD's Avatar
odd issue. I'd venture that they are not the same parameters. Did you double check with Steve?
Any chance your car gained weight? How much difference? Any other changes?
Doug
1971 RSR - interpretation
Old 10-27-2006, 02:48 PM
Make Bruins Great Again
Por_sha911's Avatar
Dumb Question: Did Steve custom program both chips for you? Is it possible that one chip was programed differently than the other?
Joe
Old 10-27-2006, 04:18 PM
ewave's Avatar
The extra weight of the 28 pin part over the 24 pin part is slowing the car down.
Paul
2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS.
Old 10-28-2006, 12:04 PM
Any possibility one DME was from a ROW and the one you have now is US ? Just a stab in the dark
Old 10-28-2006, 01:32 PM
durn for'ner
livi's Avatar
I will be very interested to hear Steve comment. I have zero knowledge of course (so why don´t I shut up?), but could it be that the newer 28 pin is designed to go with a bit different input parameters so although "programmed" identically with the old chip, it does not produce identical output ?
OK, I should have shut up..
Markus
Resident Fluffer
Carrera '85
Old 10-28-2006, 02:10 PM
ewave's Avatar
Originally posted by livi
I will be very interested to hear Steve comment. I have zero knowledge of course (so why don�t I shut up?), but could it be that the newer 28 pin is designed to go with a bit different input parameters so although "programmed" identically with the old chip, it does not produce identical output ?
It's just an EPROM... It contains the code that the cpu (an Intel 8051) runs. So if the eproms have the same programming, the output would be identical. I think my pin weight theory is correct. Try driving back to back experiments with your eyes closed to see if you can still tell the difference between the two DME's.
Paul
Old 10-28-2006, 03:21 PM
