Help!! I lost my headlights and turn signals
Hello Pelicans,
Today I was messing with the wiring under the dash, trying to clean up wires that were just hanging or snipped off. Somehow I lost my turn signals and headlights (though I have high beams). I have running lights front and rear. I checked the fuse panel in the luggage compartment; all the fuses look ok.
Could I have knocked a relay loose? What should I be looking for? What could possibly be wrong?
Old 04-19-2007, 08:30 PM
scottb's Avatar
There are a bunch of wires that run from the turn signal/high beam switch to the back of the headlight switch. Check to see if you accidentally pulled any of them off the back of the headlight switch.
1984 Targa
Old 04-19-2007, 08:34 PM
Scott,
Cha-Ching! You are the man! It was a wire plug that was loose.
THANK YOU!!!
Black 1985 Carrera ~ Whale Tail - Gone but not forgotten
2013 Boxster - Wifey Car
1969 Karmann Ghia - Next in line for restoration
"Driving in its most beautiful form"
Old 04-20-2007, 05:38 AM
I still don't have fog lights operating.. the plug is harder to get at to check if it is in all the way. But that is a luxury compared to headlights and turn signals.
Old 04-20-2007, 05:53 AM
GFCC
Jeff's Avatar
Jeffrey, Just in case you don't know, Your headlights have to be on and in the low beam position for the fog lights to work.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 04-20-2007, 06:49 AM
scottb's Avatar
I'm glad it worked out. Congrats!
1984 Targa
Old 04-20-2007, 07:06 AM
CU L8r,
That was the easiest repair ever! It works!
Thank you!
Old 04-20-2007, 07:26 AM
GFCC
Jeff's Avatar
Cool!
Jeff
Old 04-20-2007, 07:31 AM
