Unable to get engine and trans separated
Hello, I'm pulling my engine (1980 euro SC) to get it off to the rebuilder. I got all the bolts undone except the starter allen cap/ bolt thingey as it was stripped. Unable to get it out, I pulled the engine and trans as a whole. I was able to get that stupid allen head thing off the starter and it appears everything is loose but I cannot separate the engine from the transmission. A couple of things come to mind. The car has sat for about 2 1/2 years so maybe the throwout bearing is stuck to the clutch? Also, according to Waynes book, I should be able to slide the clutch lever arm off the shaft... it also won't come off... is that what is holding the whole thing together? It will separate by about a 1/2 to 1 inch but will not budge any farther... any thoughts?? Thanks, Brian
Old 04-20-2007, 05:12 AM
Irrationally exuberant
ChrisBennet's Avatar
If you don't/can't remove the smaller of the levers on the clutch lever shaft, the clutch fork won't be able to get free of the throwout bearing. (s that the case?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-20-2007, 05:20 AM
Semper drive!
rcecale's Avatar
Did you remove the Helper Spring Assembly, located on the bottom of the engine/transmission assembly?
Also, the search button works wonders. I entered "separate engine transmission" and came up with the following threads.
http://forums.pelicanparts.com/search.php?action=showresults&searchid=3034083&sortby=lastpost&sortorder=descending&searchid=3034083&exactname=yes&searchuser=&perpage=25&pagenumber=2
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Looking at the pic... does that WHOLE ARM come off the splined rod? The helper spring is undone and appears exactly as that pic shows... so there is no tension on the spring it is just dangling there. I just dont know if that arm that the spring attaches to is supposed to come off? Would that make a difference?
Old 04-20-2007, 05:51 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
The arm and spring should just lift off now.. Shouldn't make a difference but you'll want them off so they don't fall off later..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 04-20-2007, 06:22 AM
Tim L's Avatar
The first time I separated my transmission the long clutch lever was seized on the shaft. If this is the case you need to get it off so the shaft can turn. You can’t separate the two if shaft is not free to turn.
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 04-20-2007, 07:15 AM
Somatic Negative Optimist
Gunter's Avatar
Get it out of the way; use some penetrating oil and slide the release arm off the cross shaft. Then tape up the splines to protect them. Save the circlip.
Both engine and transmission need to be on a level plain.
I would carefully try some prying and hammering with a big mallet to seperate. It can be a little resistant but they will come apart unless the release bearing is rusted onto the spline of the transmission input shaft
The Allen thingy is called barrel nut.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-20-2007, 08:09 AM
Tired Member
DaddyGlenn's Avatar
The short arm must be removed and the helper spring disconnected.
The long clutch lever does NOT have to be removed to separate the engine from the transmission. It does, however, have to be able to pivot.
With the starter removed, which I assume it is, you may be able to look through the starter hole in the bell housing and see what if anything is snagging.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 04-20-2007, 08:25 AM
Gunter's Avatar
Of course the circlip, position lever and release lever along with the C-spring should come off to prevent damage to these parts.
The point is that you want the release lever out of the way to prevent it from getting damaged while the transmission is moved around.
The C-spring comes off with the release lever.
Use tape to protect the splines on the cross shaft.
Prying and hammering will seperate.
Old 04-20-2007, 08:36 AM
some of the long arms are pinned and won't just slide off. it doesn't need to come off, but as previously noted, it has to be free on the shaft.
206 637 4071
Old 04-20-2007, 08:52 AM
