But the site I referenced earlier says that the Mobil 1 and Mahle are virtually identical--possibly actually identical--in construction, case thickness, drainback valve, materials and other interior features. I think that's what Charlie is talking about...
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Interesting info...sounds credible as well.
I'm curious how the Mann engineer came to his conclusion. I should've asked.
Warren & Ron, may you rest in Peace. |
who makes aircraft oil filters? seems there would be some real testing involved there for quality!
Back in New England!
cashflyer,
Thanks for the link to that site. Very informative, and I will stop putting Fram filters on my wife Grand Cherokee. Wonder if Mahle makes filters for Jeeps? -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
well just talked to our A&P,IA guy and the mfg. he uses for all planes is CHAMPION. said there was one other mfg. but couldnt remember name off hand.
rickm too damn funny! who would have thunk?
Champion is well known for aircraft engine filters...as you say, performance should be a given for certification, both to satisfy manufacturers and FAA. Having said that, I will continue using Mahle ........
1984 RoW Cabriolet (needed me-followed me home) |
Heh heh...not sure if it's an oil filter though.
It isn't. It's an air filter.
I always used Champion oil filters on my airplanes.
Looks like Champion is the largest. Kelly seems to be another MFR.
Bill is Dead.
Amsoil's previous line of filters (the SDF line) was made by Wix... same as Napa Gold. Now Amsoil has a new line (the EAO) that has a much improved, synthetic media filter element.
I believe they dropped their Hastings line of filters, but still carry Wix and Donaldson in addition to their EAO line.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
this question may prove once and for all, what is the best or most respected oil filter for a porsche engine. WHAT FILTER WAS USED ON PORSCHES AIRCRAFT ENGINE that they once offered??????
Baldwin filters enjoy a great rep in the heavy equip. industry.
They also make filters for cars and trucks but I never checked for one to fit my SC. I use them on my other cars. |
FWIW,...The ONLY oil filters we will use are the Mahle (OC-54) ones (and before those, the German-made Purolator PC-260).
I used to keep 2, 40 gallon garbage bags here full of American-made oil filters that had ballooned or burst casings, as well as faulty anti-drainback valves. In some cases, the filter burst without the drivers knowing it and all the oil was pumped out on the ground in a few minutes. Needless to say, that was a VERY expensive experience. No Yankee filters (on Porsche's) for me,....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Irrationally exuberant
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Paper Member
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
You're lucky they didn't say, "Made in China."
