pjv911's Avatar
Send a message via AIM to pjv911
Np 12v to my WUR and Idle Speed control
On my 82 SC I just found that my wur and ISC do not have 12v going to them. I also found that my ISC doesnt have ground either.
I tested pin 10 on the 12 pin connector and power goes in and power comes out. However it doesnt make it through the engine wire harness to the components.
Also, although I havent checked it yet I believe my cold start system is down too. Its very hard to start cold. Very hard !
If it makes any difference the engine is not the 3.0 anymore but a 92` C2 turbo 3.3 engine. However I believe the same theory of operation applies to both systems.
Before I start tearing into the engine bay for answers Im hoping someone can offer helpful advice.
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 11-02-2006, 04:42 PM
911mot's Avatar
Check the engine bay fuses and relays. I had the same problem a few years ago with my previous car. I ended up using a wire to jump terminals as I couldn't get a relay. Can't remember which terminals though.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 11-02-2006, 05:06 PM
pjv911's Avatar
The loss of voltage is after the 12 pin connector on the engine side. So it cant be an engine bay fuse. From what I understand the power originates from term 30? of the fuel pump relay. Well the 12v is there too.
Kurt Williams
Old 11-02-2006, 05:38 PM
Elombard's Avatar
Yoau re correct the AAV is on the same circuit as the WUR (at least iit is on some SCs). I had a similar problem but my problem was on the realy side. There was a post onthis recently and I think the ground is not an issue for some reason.
anyway, it has to be a broken wire doesnt it? Can you rig a jumper to the WUR, it shoudl fire your cold start stuff as well. Then trace it back?
Sorry you are an advanced user thats a simple idea.....hopefully some one with a clue will chime in
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 11-02-2006, 07:50 PM
pjv911's Avatar
Thanksa Eric. Yes a jumper would be a quick fix but I would end up leaving it that way if I did (bad). So whether or not I get any helpful advice im going to dig in this weekend if I get the time.
As for the ground ? Well that would be nice but in all my 911 experience all solid brown wires are constant unswitched ground. But hopefully you are right and its not an issue.
Kurt Williams
Old 11-02-2006, 07:57 PM
pjv911's Avatar
bttt
Old 11-03-2006, 06:16 AM
pjv911's Avatar
Anyone else have any insight ?
Old 11-03-2006, 04:34 PM
Warren Hall Student
Bobboloo's Avatar
Are you checking for voltage with the engine running or just with the ignition on. I forget which year it changed but later CIS cars did not supply voltage to the fuel pump and warm up ancillaries (WUR, AAR etc.) unless the motor was running.
This serves two purposes. Safety and prevents pre-heating of the warm up ancillaries.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-13-2006, 11:16 AM
pjv911's Avatar
I havent touched the car for over a week. I dont recall if it was running or not. I will keep that in mind when I get back to it. Thanks,
Kurt Williams
Old 11-14-2006, 06:20 PM
Voltage supply to WUR, AAV, CSV.....
Kurt,
Bobby is right on spot. For the SC's, voltage is supplied to these CIS components via the alternator (engine has to crank) to get energized.
TD
Old 11-14-2006, 06:41 PM
