Russellh911's Avatar
Weber float bowl mod epoxy type
Since I'm into rebuilding the carbs, thought I would do the float bowl mod and add the dam in the bottom. I've searched the archives unsuccessfully and Jerry doesn't specify in his book, so the question is: what type of epoxy works?
I did see a picture posted showing a set that were sent to Jerry Woods, and that looks like good old JB Weld, but that doesn't mean it's so. Do I need some custom $80 per kit type product that can survive immersion in gasoline?
Thanks,
Russ
Russ Hildebrand
russellh911@yahoo.com
Aledo, TX
Old 11-05-2006, 08:05 AM
gumba's Avatar
JW mills a shelf in the bottom of the float bowl that the plate sits on before it's epoxied in. There may by other work involved. I posted a shot showing the mod.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 11-05-2006, 08:21 AM
use the epoxy sold to repair gas/fuel tanks,it`s a slightly different formula and available at large auto parts places
my life begins at 150MPH
Old 11-05-2006, 08:25 AM
But any idea of the epoxy product he uses?
Russ Hildebrand
Aledo, TX
Old 11-05-2006, 08:31 AM
Thanks raceman, I posted back to Gumba just as your hit. I'm off to the store.
Russ Hildebrand
Aledo, TX
Old 11-05-2006, 08:32 AM
