Procedure for changing brake light switches
What is the procedure for chamging the brake light switches?
Do I have to bleed the brake fluid out first or anything?
Do I have to put pressure on the brake pedal while I remove and install them?
Thanks.
-Scott
Old 11-03-2006, 06:47 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
78SC Brake switches
If you're speaking to the 2 pressure swithces that are screwed into the Master Cylinder, no you won't need to bleed. You will bust your knuckles up a bit likely. The VW part for the same year as a 911 will work if you have 78 3.0L. No need to put pressure on brakes.
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 11-03-2006, 06:54 PM
Thanks. I got part number 113 945 515 H (2 of them). It's the 2 prong one which is what is in the car.
BTW, nice MR2. Are you on MR2OC?
-Scott
Old 11-03-2006, 10:09 PM
Administrator
Jack Olsen's Avatar
If you're hoping to fix late activation, you may also want to read through this thread.
Old 11-03-2006, 11:52 PM
