Brake Bleeding? Do it before or after changing pads ?
My first time changing pads on my 79 SC Targa. I will be flushing the brakes while I'm at it...Is their any reason why I should be doing this in a particular order? After searching through threads on changing brake pads and bleeding brakes I did not find any comments about what order I should do the two projects.
I will be doing the gravity method for bleeding the brakes as it seems to be the simplest (I'm a mechanical novice). Thanks for your comments on the subject, and any tips that will make these jobs go smoother.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
If your pads are very worn, you will likely need to suck some fluid out of the reservoir to make room. I use a turkey baster for this. So change the fluid after you replace the pads to save the new fluid.
Don't know what you mean by gravity drain but get a pressure bleeder for a full flush. They make it very easy - well worth the $50.
'82 911SC racecar '05 WRX STi |
Do pads first, then change your fluid. Then, the new pads will be seated against the rotors....
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles Last edited by LakeCleElum; 11-11-2006 at 11:11 PM.. |
Southern Class & Sass
It makes absolutely no difference.
That said, here's my personal preference…
Dixie Bradenton, FL 2013 Camaro ZL1 |
Thread Tools | |
Rate This Thread | |
