hillelson1's Avatar
Send a message via AIM to hillelson1
weber tuning and rebuilding question?
what tools are needed to rebuild and tune the weber 40mm carbs. does anyone have an exploded diagram of these carbs?
thanks
-larry
Love cars lucky i got an early start
1989 911turbo project
1928 rolls royce
Old 11-12-2006, 12:14 PM
Autobahn Garage
Carb cleaner, screw driver, 1/4 socket set, carb sync,101 projects for your 911!!!!! and about 5-10 hours of time
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 11-12-2006, 03:58 PM
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 11-12-2006, 06:43 PM
hillelson1's Avatar
thanks for the diagram you wouldn't by chance have a key for it describing what the numbers are?
1928 rolls royce
Old 11-13-2006, 07:41 AM
wreckah's Avatar
you will need a carb rebuild set with all the washers, rubbers, gaskets, ...
you will need compressed air too to blow everything out.
we did it on our 69T a few months ago, with no real technical background. Just take your time, nothing much can go wrong.
we took a lot of pics during the dismantling of the carbs, so we could always look back to see how a part was mounted in case we forgot
it took us about 1 day per carb, and that's including cleaning the whole body with toothbrush etc..
before: '69 Porsche 911T bahama yellow
now: 1981 911 SC Targa winered
Old 11-14-2006, 12:40 AM
DOUG
Old 11-14-2006, 10:57 PM
hillelson1's Avatar
thank you so much
1928 rolls royce
Old 11-15-2006, 07:31 AM
T77911S's Avatar
taking it apart and putting it back together is not the hard part. setting the mixture was always tough for me, with a unisyn the rest is easy.
go buy a 5 gal can of carb cleaner fron napa or advance, great stuff, but dont put anything in there with paint on it casue it wont be on there if u leaveit very long. good luck
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-16-2006, 09:39 AM
