upgrade rear calipers on SC to Boxter
Now the time has come to upgrade my brakes, i have changed the head studs, upgraded chain tensioners, new Dansk exhaust (realy nice sound) and converted to 964 cam profile.
I now have a pair of Boxter rear calipers and disks that i want to use on my 1981 SC. I think i have see a drawing on this forum that shows how to adapt these calipers, but i can't find it. Does any one know how to do this? I will use 964 brakes in front as i have been informed i can put them right on. Thanks Kjell R My god i love this car ![]()
I installed mine with a kit that included an L-shaped bracket that mounted to the original brake mounting holes on the bannana arm and allowed mounting the Boxster caliper on top of the axle as shown. Unfortunately I don't have a picture of the bracket. You will need to fabricate new brake hard lines to go from where the flexible lines terminate to the new caliper. It is possible to bend the old hard line if you are very careful and brave.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
The 930 does have spacers, but not to that extreme. 28mm in the rear if I remember correctly. It looks like there are two different spacers being used in this application.
'99 996~LSD~VE Wheels~H&R Cup Kit~Aero~Recaro~X51~M&K~GT3 Roll Bar '77 911 ~ very modern running gear ~ Gruppe B...the Midwest motorsports playground |
Somewhere in the Midwest
No need to put the Boxster brakes in the rear, just get the Carrera rear caliper and rotor (no adapters, not hassel). I'm running 964 front caliper and Carrera rear caliper on my '89. Works well so far with a track weekend of testing
Work in Progress
Not that I am an expert on Brakes or anything. From what I understand Boxster brakes have greater clamping force than carrera brakes. But becasue the stronger caliper is being used on the same size rotor the heat energy builds up faster in the rotor and actually makes the problem with frequent track braking worse. Is this wrong?
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Here we go again... Sounds like thechiller already has the parts so he just needs to get them on. I think TRE in SoCal makes the adapter referred to here. I am pretty sure that Smartracing Products have obtained some and put them on some customer cars, and a few of our Porsche Racing Club Spec 911 racers have them.
I have a friend with a GT car and Boxster rears with a homemade bracket-- I will see if he has a drawing. For my car ('75 race car at ~2000 lbs and ~360 bhp), 930 rears would be a little foolish. Not worth the weight. Car stops fine with the itty bitty Carrera calipers in the back. The only reason I might put Boxster calipers on is the save money on rear pads... Anyway, try googling +TRE +Porsche-- I think they have a kit, also try VCI in NJ. And remember, how "much" brake you need depends on weight, HP, and tires. Bigger and heavier may actually increase your lap times.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
If you want to use Boxsters you should at least use some bigger Wilwood rotors
Disagree completey depending on the factors involvded. For example, if I put 930s or bigger on the rear of my car (where all of the wieght is) I am sure I'd go slower. My point is that regrading brake choice, one must consider the car and the tracks and...
A good resource on brakes is the Puhn book.
hopefully we are not including doing something dumb like only addressing one end of the car
Oh no. This is what I am referring to:
"Intermediate steps which are cheaper and have fewer negative side effects should be tried first as the principal design goal should be to use the smallest lightest combination which will do the job." That is my point (and yours I presume). - MM
Schleprock
Re: upgrade rear calipers on SC to Boxter
Cutting off the mounting ears and affixing caliper adapters onto the calipers is how it's done properly, along with using the appropriately offset 28mm or 32mm rotor. Using a 24mm rotor with caliper that is designed to use a 28mm rotor is dangerous, as the pistons can actually fall out if the pads are allowed to wear far enough!
Kevin L '86 Carrera "Larry" |
Schleprock
http://www.tremotorsports.com/product.cfm?Node=1329 Another adapter source http://www.timmonsbillet.com/Porsche.html VCI doesn't do anything with the Boxster/monoblock calipers (yet).
the next step would be Boxster on ~310x28mm rotors(front) then 930 then 993 then 993tt/RS. This last is overkill for almost any stock car, the others it depends on all the other factors. The fact is that just changing the front calipers and rotors to Carrera is a nice and sufficient step for many cars. The Boxsters on Carrera isn't enough better to warrant the steep price differential, if you like the looks fine.
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 10-27-2006 at 02:23 AM.. |
Bill,
Do the Boxster calipers need to be machined to fit a 28mm wide rotor? I've never heard of this before (always thought they only fit the 24mm Carrera rotor), but may be interested with using stock carrera rears with the 24mm rotor. Thanks
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Boxster S used 28x314 front rotors and 24x299mm rear.
AFAIK the regular Boxster can also use the 28mm rotors w/o issue, but I don't go there so am not sure.
Mahler - you held your own pretty good there with Bill on this thread... Then he kind of laid 4 queens down and you ought to 'tip your hat' as they say.
_____________ '82 Targa - sold '80 928
nice doggie
I've always thought SC brakes were quite good.
Jerry 78 SC hotrod 02 Mini Cooper S |
