dash swapping
Can anyone tell me which year models (particularly 70's -80's) would share dashes? Ie: can I put a '77 dash in a '73, etc? Are there any peculiarities in mounting, etc? Hope someone can share their knowledge here...
Old 11-13-2006, 11:16 AM
Warren Hall Student
Bobboloo's Avatar
I think 77' in a 73' would work. Before 72/73' the stud spacing was a little different but can be worked around using a drill to add a couple extra holes.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-13-2006, 11:38 AM
PRO Motorsports
Tyson Schmidt's Avatar
Yep the stud spacing is different on the face, and also on the top where the stud sticks down behid the gauges.
Also, you'll need to cut a square hole so the center vent will fit. '77 was the first year for the center vent.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 11-13-2006, 12:54 PM
Tim K's Avatar
Backwards, but you can see the difference between them here:
Early dash in an SC:
On the right the stud on the dash is hiding just between the vent opening and the mounting hole.
Hope this helps
Tim K
Old 11-13-2006, 03:13 PM
