dash swapping
Can anyone tell me which year models (particularly 70's -80's) would share dashes? Ie: can I put a '77 dash in a '73, etc? Are there any peculiarities in mounting, etc? Hope someone can share their knowledge here...
Warren Hall Student
I think 77' in a 73' would work. Before 72/73' the stud spacing was a little different but can be worked around using a drill to add a couple extra holes.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
PRO Motorsports
Yep the stud spacing is different on the face, and also on the top where the stud sticks down behid the gauges.
Also, you'll need to cut a square hole so the center vent will fit. '77 was the first year for the center vent.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Backwards, but you can see the difference between them here:
Early dash in an SC: ![]() On the right the stud on the dash is hiding just between the vent opening and the mounting hole. ![]() Hope this helps Tim K |
