another round please
strupgolf's Avatar
lighting problem--any answers
What would you look for if one minute the parking lights front and back go off. I checked the fuse, ok. Bulbs are ok. I had them last week and now I cant get them to come on. I'm no expert on this stuff, so any help would be appreciated. Thanks. 1986 911 3.2 Targa
Getting old is not for wimps.
Old 11-18-2006, 05:17 PM
ajmarton's Avatar
For me it was the connectors being fouled up with black ozidation. Check them. Also, make sure you are checking the right bank of fuses. I would remove and re-install the specific fuses to make sure they are seated right.
Old 11-18-2006, 07:58 PM
one of gods prototypes
bell's Avatar
also check the flat round rubber plug under the dash to the left of the column, mine worked loose once and drove me nuts until i found it......
Brought to you by Carl's Jr.
Old 11-18-2006, 10:04 PM
Driving member
jester911's Avatar
Since you have an 86 your problem may be a small diode located under the dash. I believe this is in the 86 year only. It is in an opaque rectangular connector that should be just to the left of the steering column.
I will try to find the part #. This diode actually only effects one side of the parking lights but it still may be the cause of your problems.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 11-19-2006, 05:09 AM
After the bulkhead connector that was mentioned I may go after light sw connections to see if power is still being delivered when they go out. If it's intermittent I'd probably hook a temporary wire to the sw output to see if it's still hot when the parking lights go out. Light sw's do go bad.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-19-2006, 07:25 AM
