Porsche Crest Not the normal noise in here!!!
I hope someone else out there has experienced this, I have run into dead ends so far. My 81' SC Coupe (no sunroof), has a lot of engine noise coming in from the vent slots above the rear window. If I am sitting in the car with the windows up and the motor off, any noise from around the rear of the sounds as clear as if I had no rear window. What and how much insulation should there be between the headliner and the roof? This is my second 911 and the first was not at all like this. Curious....
Old 11-22-2006, 05:32 PM
plymouthcolt's Avatar
I have an '88 and it's the same for me. While sitting with the windows up, I ccan hear everything just like the windows were down.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 11-23-2006, 06:55 AM
Re: Not the normal noise in here!!!
both of mine have been like this.... now even louder since Ive changed the exhaust... My Rover is quiet..so it dosnt bother me much, if I want quiet, i drive that...at least I dont have to answer the phone becuase I cant hear it
Current: 1973 914/4 project. FOR SALE
Old 11-23-2006, 06:58 AM
DGL DGL is offline
My 88 has the same noise issue and if it rains hard enough water bounces into those vents in shockingly large quantities. I haven't had the nerve to rip out the headliner yet, but in my research I've not seen a source that carries replacement parts for the headliner foam. Anyone know where I can get that?
Old 11-23-2006, 07:16 AM
More on "not the normal noise"
At least I am not the only one to wonder about this. And not the only one to wonder about a solution. I was considering weaving some open cell foam with adhesive on one side, from one side through to the other with a stiff length of wire and pressing against the metal to hold it in place. Since the slots are there to equalize pressure I don't think that would hurt anything...am I way off here?
Porsche list...
81' 911 SC Coupe
84' 944 Coupe
69' 911E Coupe
73' 914 2.0
Old 11-23-2006, 06:42 PM
Throw it on the ground!
Thanks for bringing this up again. I Posted a thread on this problem a week ago and got no replys.
Here's what I said:
Noisy rear window vents
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-24-2006, 08:08 AM
Picture of vent with missing foam.
Mark
1987 911 Coupe
Old 11-25-2006, 05:59 AM
Vereeken's Avatar
Yes the foam should be in those vents, or you will suffer extra noise. Since you do not have sunroof you also have no zipper in the headliner to get to the sunroof motor. If you would have disassembled that you will notice that there is a lot of foam to quit thing sdown. I assume that without if it acts like a loudspeaker.
Here is a suggestion to quite things down and add some safety....
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses.
Old 11-25-2006, 08:53 AM
Designer King
Paulporsche's Avatar
So it looks like the foam extends the width of the vent area, and I'm assuming it fills the entire gap up to the underside of the roof, but can anyone tell me how big it should be, front to back?
Thanks for that photo, Mark.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-25-2006, 03:26 PM
Designer King
A bump to see if anyone knows this.
Paul
Old 11-26-2006, 07:42 AM
Vereeken's Avatar
In my SC it is a three piece cardboard plate with the foam glued on to it, it is basically as wide as the total vent area and runs from the back some 25cm inward to the front of the car, mind you my SC has a sunroof , but I do not think that in a non sunroof car it will be bigger as you would hit part of the roof structure pretty soon, but you could get more insulation in place of the sunroof motor.
Michel
Old 11-26-2006, 08:47 AM
Designer King
Thanks, Michel. That's a big help.
Paul
Old 11-26-2006, 11:52 AM
