I hope someone else out there has experienced this, I have run into dead ends so far. My 81' SC Coupe (no sunroof), has a lot of engine noise coming in from the vent slots above the rear window. If I am sitting in the car with the windows up and the motor off, any noise from around the rear of the sounds as clear as if I had no rear window. What and how much insulation should there be between the headliner and the roof? This is my second 911 and the first was not at all like this. Curious....
I have an '88 and it's the same for me. While sitting with the windows up, I ccan hear everything just like the windows were down.
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
Re: Not the normal noise in here!!!
both of mine have been like this.... now even louder since Ive changed the exhaust... My Rover is quiet..so it dosnt bother me much, if I want quiet, i drive that...at least I dont have to answer the phone becuase I cant hear it
Current: 1973 914/4 project. FOR SALE |
My 88 has the same noise issue and if it rains hard enough water bounces into those vents in shockingly large quantities. I haven't had the nerve to rip out the headliner yet, but in my research I've not seen a source that carries replacement parts for the headliner foam. Anyone know where I can get that?
More on "not the normal noise"
At least I am not the only one to wonder about this. And not the only one to wonder about a solution. I was considering weaving some open cell foam with adhesive on one side, from one side through to the other with a stiff length of wire and pressing against the metal to hold it in place. Since the slots are there to equalize pressure I don't think that would hurt anything...am I way off here?
Porsche list... 81' 911 SC Coupe 84' 944 Coupe 69' 911E Coupe 73' 914 2.0 |
Throw it on the ground!
Thanks for bringing this up again. I Posted a thread on this problem a week ago and got no replys.
Here's what I said: Noisy rear window vents Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 11-24-2006 at 11:24 AM.. |
Picture of vent with missing foam.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Yes the foam should be in those vents, or you will suffer extra noise. Since you do not have sunroof you also have no zipper in the headliner to get to the sunroof motor. If you would have disassembled that you will notice that there is a lot of foam to quit thing sdown. I assume that without if it acts like a loudspeaker.
Here is a suggestion to quite things down and add some safety....
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses. |
Designer King
So it looks like the foam extends the width of the vent area, and I'm assuming it fills the entire gap up to the underside of the roof, but can anyone tell me how big it should be, front to back?
Thanks for that photo, Mark.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Designer King
A bump to see if anyone knows this.
Michel
Designer King
Thanks, Michel. That's a big help.
