North Coast Cab's Avatar
Adding Webers to a 2.7
I have an opportunity to throw some 40 webers on a basically stock 2.7 motor. Is it worth the time and hassle and what gains can be made? The webers would be virtually free and I'm not looking to do a bunch of other engine work other than exhaust.
John
1985.5 944 GTS
Old 11-29-2006, 08:21 AM
ckissick's Avatar
Although I don't have any experience with CIS, conventional wisdom says you will feel noticeable gains in throttle response and the car will feel faster. I used to have a 2.7 with Webers, and the car ran great. Now I have a 3.0 with the same Webers and it still runs great.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 11-29-2006, 08:45 AM
Senior Member
If you like tinkering and like carbs then try it. Personally unless you track the car or really are not happy with the performance, I would stick with the CIS. It works well when correct and would be a lot better fuel mileage than the webers.
I love carbs but as I get older do not want to putz with somethings, and the webers usually need some fiddling with from time to time.
Old 11-29-2006, 08:58 AM
Air Medal or two
afterburn 549's Avatar
your wide oped to opinion..carbs mandatory ( or Fuel injection ) if your gonna bump the C/R...as CIS wont let you (reversion) You have no reason to go to carbs unless you bump C/R as your hp/ TQ will stay the same......X amount fuel =x amount of pwr.....you changed nothing except maybe your throttle response
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 11-29-2006, 09:39 AM
Neil Peart Fan
Pele911's Avatar
Instead of webers install the Electromotive crank fire ignition. The CIS and an almost continual spark of the crank fire makes for a good combo.
Old 11-29-2006, 10:54 AM
drag racing the short bus
dd74's Avatar
John - give it a try, but keep the CIS just in case things don't work out. IMO, the Webers offer more performance, even on a CIS engine. They weigh less than CIS by about ten pounds, and usually you can tune them to run well with CIS pistons. Certainly, you won't maximize their ability with the CIS pistons, but there are benefits to Webers, such as a cooler running engine.
Gas mileage can depend as much upon your gearing as your engine. For instance, if you have a 7.31 ring and pinion, you're not going to get very good mileage, even if you have CIS.
The Terror of Tiny Town
Old 11-29-2006, 11:10 AM
bigchillcar's Avatar
ask art (azasadny). he's having webbers put on his 2.7 right now..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 11-29-2006, 12:27 PM
haycait911's Avatar
I have 40 IDAs on my 2.7, I've found them very reliable, balance them once a year and go! biggest drawback is fuel economy, about 15-16 mpg. mind you that may have something to do with the skinny pedal spending so much time on the floor. Don.
Old 11-29-2006, 05:00 PM
randywebb's Avatar
Do it. You get great sounds, seemingly better throttle response, no more power.
But... more emissions & worse fuel economy. Not a biggie if you live outside an emissions control area and don't drive the car much.
There are at least two prev. threads on this.
Add SSIs too...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 11-29-2006, 05:51 PM
