Sports Purpose 911 Driver
Where can I find one of these?
I have installed some later model footwell blower motors. These require the use of one of these guys to modulate the speed of the blower motors depending on the position of the switch.
So... Anyone know where I can get a new one? Thanks!
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
I'm with Bill
The part you seak is called a blower resistor
Electrical problems on a pick-up will do that to a guy- 1990C4S |
ok, thanks.
That is commonly known as a wire ound resistor with a center tap. What it does is allow the motor to run in two speeds by selecting the long path, more resistance, less speed or the short path less resistance more speed.
They can be obtained from any electronics house, you need to know the resistance between the ends. You can buy them with and adjustable center tap too, for a song and a dance.
Al Morales 77 911 S (930 steel conversion) 88 BMW M3 79 Honda CBX |
