Bouncing tach?
Hey,
The tach on my 74 bounces quite a bit. It just seems to take a min to "catch up" when you really hammer on it. It makes it difficult to read especially when you get on it in the lower gears. Any suggestions? Thanks, Pat
'74 911 options delete no sunroof. lowered, swaybars, tie bar, braided brake lines, corner balanced, "s" gauges, 993tt seats, Momo wheel and knob, 993 mirrors, blacked out window trim, H4's, short gearing, S pistons, stand alone EFI, other stuff. |
I seem to remember this being a symptom of dirty points. You might check your points and make sure the contacts are clean. Might be an easy fix.
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I believe that symptom is common to a failing voltage regulator.
1972 911T 1972 911E "RSR" |
Mine started bouncing just as the alternator died.. Replaced the alternator and problem went away! Mine had teh intergrated voltage regulator, so hopefully it is that easy?
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
I second the point's responce. Could be dirty or just have a weak spring.
put a multimeter on the battery, record if it has the option.
my brothers tach was acting up, voltage was jumping to 17v!
Was the voltage jumping when he revved it? I'll give it a try this evening. Thanks
Pat
when the tach was jumping so was the voltage
