Guest
Posts: n/a
What's best way to increase torque for $2000?
I have a 89C4 with RUF chip and after cat bypass pipe ie. only one stock muffler left in exhaust chain, everything else is stock.
Should I spend $2000 on B&B headers and mufflers for best increase of torque? |
Guest
Posts: n/a
For torque I would eliminate the air flow meter in favor of a MAF system.
http://www.huntleyracing.com/ Joe Garcia 86 Carrera [This message has been edited by stlrj (edited 09-24-2000).] |
Guest
Posts: n/a
Hi, could you give me more details on this? I'm a new owner. Where do I get the MAF system?
Guest
Posts: n/a
Check back through the past threads for exhaust questions. People have some pretty strong opinions about B&B systems. I have none, so I won't repeat what was said...
Guest
Posts: n/a
Whoops, bad information.
[This message has been edited by JackOlsen (edited 09-24-2000).] |
Guest
Posts: n/a
Poski, I have the MAF system that Joe talks about. Check it out at: http://users.ev1.net/~davmanku/porsche/engine/maf.html
Guest
Posts: n/a
[This message has been edited by beetos (edited 09-27-2000).] |
Guest
Posts: n/a
Betos,
How many bux are we talking about? How about smog testing? Thx, JoeA |
Guest
Posts: n/a
Betos,
Guest
Posts: n/a
Guest
Posts: n/a
Thanks guys. I have gone through the entire message board (back 45 days) and only found comments that SSI is good bang for the buck and B&B is expensive. No talk about effectiveness. Torque is more important to me than bhp.
I'm thinking of a more major upgrade later next year like 3.8 conversion or camshafts or flywheel or combi. Turbo is out. But like to look at maybe exhaust first unless something else is a better $2000 upgrade. |
Guest
Posts: n/a
Sorry about the multiple posts, Huntleys site should have prices, I think it should run around 1500 bucks. As far as I am aware, emmisions should not be impacted as the MAF is just a more efficient way of metering the inlet air and does not necessarily compromise the engine emmisions (unless you want it to!). I would check out you local regulatory requirements.
