Weber 40 Rebuild Question
Is it possible to remove these tubes? One of mine is bent and I would like to straighten or replace it while they are apart (This picture isn't my carb).
Just tap it straight with a soft hammer it will be fine Cheers
It got bent pretty bad in shipping so I'm affraid it will be kinked pretty bad if I try to straighen it.
Is there any way to remove and replace them?
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Can you find a rod that is the same diameter as the inner diameter and gently tap it in? Silicone or oil so it comes out easily. Never tried it just a thought.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
It is not able to be removed easily as it is burred over underneath the base.It is only a breather it wont kink & as long as the air cleaner base will go back on it can be bent a little & will work fine.Cheers
