unusual electrical problem
Tonight while driving my 80 SC an electrical problem occurred.Intermittently the seatbelt light would come on the tach would jump & the headlights would get very bright.I think it
burned out the high beams. Has anyone experienced this problem?
76-911s 80-911sc Regards Lester |
Check the voltage output from the alt. Might have a bad regulator or bad connector in the charging system.
bizerk voltage regulator.
Failing Voltage regulator ... high Voltage spikes!
Check/monitor your system Voltage ... plan on getting a new Voltage regulator, soon!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Patton No Porsche at the moment but give me 6 months and then...... |
After reading Jim Thorusen's troubleshooting guide on this site I removed the alternator and found the D+ connection to the voltage regulator loose.The regulator looks at D+ to determine excitation current in the alternator.If the regulator sees low or 0 voltage at D+ it increases excitation current which raises output voltage.Anyway I put the alternator back in and drove several test miles with no voltage spike problems.
Note;my alternator was a Valeo with internal regulator. Thanks for all the help!
