dhw dhw is offline
3.2 msd coversion
OK so one more question...
I am thinking of installing an MSD 6al on my 3.2 motor. Has anyone done this that could comment on whether this is worthwhile?
Also the motor is in a 1975 911s, does this need the adapter to run correctly on this particular tachometer?
'75 911s 3.2
'88 Scirocco 16V
'65 F250
Old 01-26-2006, 02:23 PM
Irrationally exuberant
ChrisBennet's Avatar
The Motronic engine management system doesn't suffer from any problems that the MSD unit could solve i.e. it wouldn't be an "upgrade".
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-26-2006, 02:59 PM
dhw dhw is offline
currently the tach is pretty sloppy, it moves smoothly but kind of flops on either side of where the engine is actually at... Does anyone know if this is from the mismatch between the motronic and the 75 tachometer or does the tach need to be rebuilt?
'75 911s 3.2
'88 Scirocco 16V
'65 F250
Old 01-26-2006, 03:38 PM
I'm sorry, I dunno.
-Chris
Old 01-26-2006, 03:41 PM
DHW:
Send your tach to North Hollywood Speedo and ask them to dampen the needle movement,....
Works just great!
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-26-2006, 04:30 PM
Lorenfb's Avatar
Better yet, send it to Pelican who has an excellent tach & speedo source.
Some shops have reported problems with the above mentioned.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 01-26-2006, 07:27 PM
My 74 tach works fine with my 86 3.2.
Old 01-27-2006, 12:36 AM
dhw dhw is offline
thanks guys!
'75 911s 3.2
'88 Scirocco 16V
'65 F250
Old 01-27-2006, 07:24 AM
Addicted to Porsche
bcaway's Avatar
I installed MSD 6A in my 3.2 carrerra motor which is in a 74s
I did upgrade my tach during the engine install so it would work with the motronic.
Here is my post: http://forums.pelicanparts.com/porsche-911-technical-forum/313547-msd6al-carrera-3-2-engine.html#post2986189
1974 911S
1990 964 C4
1998 993 Carrera S
theporschaholic.com
Old 12-15-2006, 09:52 PM
By the way, what's the advantage of the MSD over the stock DME ignition?
Old 12-17-2006, 08:02 AM
Thanks Bcaway,
I'm getting ready to do the same, a few questions: I also purchased the tack adapter is it really needed? How does the motronic control the rev. limiting..solely by the chip? I have the 6AL unit which can manually control the rev, which overrides which...the motronic or the manual rev jumpers?
Thanks for your time and sorry to jump into this forum but very helpful information!
Best Regards,
Alex
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 12-17-2006, 09:07 AM
Warren did a nice write up on the tach's different elec profiles.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-17-2006, 09:10 AM
Addicted to Porsche
bcaway's Avatar
I just use the chip RPM limiter (steve wong chip) I believe mine is set to 7000, I dont know how the MSD rpm limiter would work, as the stock CPU in the motronic would cut in at 6800. where are the manual rev jumpers? (on the MSD 6AL?)
FYI, I dont think there is any more top end power, but the economy is way better and the low end better, + it feels more responsive and smooth.
Lastly no I did not use the MSD tach adapter (have brand new one for sale now!)
The Motronic is connected directly to the tach and the signal is sent to the ecu via the flywheel triger.
are you running a stock ecu chip? highly recomend steve wong one - at least 10% difference, especially low end torque!
bcaway
1974 911S
1990 964 C4
1998 993 Carrera S
theporschaholic.com
Old 12-17-2006, 11:43 AM
The rev. limiter chips are directly on the 6AL unit, on the lower side. I too bought the MSD tach adapter because Wayne's 101 project book recommended it. I have several performance chips but I'm going to get rid of them and go with a Steve Wong.
Thanks,
Alex
Old 12-17-2006, 07:38 PM
